[mapserver-users] OGR ODBC Layer with Password
Donald Kerr
donald.kerr at dkerr.co.uk
Tue Dec 17 14:15:16 PST 2013
Jeff,
I've tried all the combinations that I can think of and the following also
works (creates test.png with the map & features) outside of mapserver on the
command line:
with:
CONNECTION "ODBC:Admin/MyPassword at MyDSNName,MyTableName"
in the map file.
The following two also work:
CONNECTION "ODBC: /MyPassword at MyDSNName,MyTableName"
CONNECTION "ODBC: /MyPassword at MyDSNName"
...but no joy with MapServer.
I've tried combinations of ' and "" - no luck.
Many thanks.
Regards,
Donald
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: 17 December 2013 20:47
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] OGR ODBC Layer with Password
On 2013-12-17 4:41 PM, Donald Kerr wrote:
> Jeff,
> Same password error, I'm afraid. It's as if MapServer is not passing
> the username/password combination.
> Many thanks.
> Regards,
> Donald
I've been here before. Did you create a "System" DSN on Windows?
Then I usually look into the slash (Admin/MyPassword), and I also might
debug using single/double quotes (all usual Windows debugging joy).
-jeff
Jeff McKenna
MapServer Consulting and Training Services http://www.gatewaygeomatics.com/
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2014.0.4259 / Virus Database: 3658/6928 - Release Date: 12/17/13
