[mapserver-users] cannot change coordinate system when using MapCache to serve to ArcGIS clients
Brent Wood
pcreso at pcreso.com
Mon Dec 30 11:29:14 PST 2013
Hi Mark,
Is your WMS service advertising "county coordinates" as a supported CRS?
If the WMS default CRS is WGS and no other is advertised then (in my limited experience) Arc will only request content in an advertised CRS - so your default of WGS is the only one it will request.
Brent Wood
To: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Sent: Tuesday, December 31, 2013 8:20 AM
Subject: [mapserver-users] cannot change coordinate system when using MapCache to serve to ArcGIS clients
Hello,
For some reason ArcGIS will only consume my MapCache WMS service in GCS_WGS_1984. This causes the air photos to be reprojected once on the server (County Coordinates-->WGS) and again on the ArcGIS client ( WGS --> County Coordinates). I would to avoid reprojecting my air photos. Unfortunately, nothing happens when I open "Change Coordinate System" in ArcMap then select County Coordinates. Is this an ArcGIS issue, or is there a problem with MapCache?
Thanks
Mark Volz, GISP
GIS Specialist
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20131230/f45b5fcf/attachment-0001.html>
