[mapserver-users] Combined spatial and attribute query
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Fri Feb 8 08:49:39 PST 2013
How about doing two WFS requests in a row? In pseudo SQL
1) select geometry from town_polygons where town='my_town'
2) capture the geometry from the previous and use in the WFS Intersects filter
select * from my_features where [attribute filter] AND [Intersects filter with selected_town_polygon]
I know it is doable, we use that in some OpenLayers applications just like you plan. User can draw a polygon or select a region name from a drop down menu which makes the application to do the first WFS query automatically.
-Jukka Rahkonen-
Bistrais, Bob wrote:
> Interesting thought. Bbox won’t quite do it- the spatial select would be based on, for instance, a selected > county or town, or a user-defined polygon.
From: Lime, Steve D (MNIT) [mailto:Steve.Lime at state.mn.us]
Sent: Friday, February 08, 2013 11:05 AM
To: Bistrais, Bob; mapserver-users at lists.osgeo.org
Subject: RE: Combined spatial and attribute query
Is your spatial query just a bbox? If so then just set that as your map extent as part of doing your attribute query (attributes always do both). There are other options too, let us know more what your spatial query is.
Steve
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mapserver-users-bounces at lists.osgeo.org] on behalf of Bistrais, Bob [Bob.Bistrais at maine.gov]
Sent: Friday, February 08, 2013 10:01 AM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] Combined spatial and attribute query
Does anyone have advice on the best or most efficient way to query data, involving both a spatial and an attribute query. I need to query several layers, selecting based on an area, then select from that selection based on an attribute value. It would be OK to query by the attribute first, then spatial.
