[mapserver-users] QGIS vs Mapserver someone use wrong scale ?
Carlos Ruiz
boolean10001 at yahoo.com
Wed Feb 13 15:02:27 PST 2013
Andrea,
I'm having the same problem with scales working with a WMS layer and QGIS.
I've defined my layer like this:
LAYER
NAME "2011"
TYPE RASTER
STATUS DEFAULT
MINSCALEDENOM 250000
MAXSCALEDENOM 5000000
END
I can't get the image when I set the scale to 1:250000. Trying with some discrete scales upwards, I find that the image finally shows at 1:335000.
So I don't know if is a QGIS or Mapserver problem, I'm performing some tests to see where the problem is, maybe that could help to find a solution.
Cheers from México
IC Carlos Ruiz
To: mapserver-users at lists.osgeo.org
Sent: Monday, February 11, 2013 4:40 PM
Subject: [mapserver-users] QGIS vs Mapserver someone use wrong scale ?
I set a class rule to show the label in this interval scale:
LABEL
COLOR 175 109 134
OUTLINECOLOR 255 255 255
OUTLINEWIDTH 1
MAXSCALEDENOM 300100
MINSCALEDENOM 1
After I try to test it with QGIS, but I see calling it with qgis the
show of labels in the scale are not so linear as I could guess.
infact
the label ARE NOT SHOWED at 1:299.990
the label ARE NOT SHOWED at 1:300.000
the label are showed at 1:300.001
the label are showed at 1:300.010
the label ARE NOT SHOWED at 1:300.050
the label are showed at 1:300.090
the label ARE NOT SHOWED at 1:300.100
the label ARE NOT SHOWED at 1:300.110
the label ARE NOT SHOWED at 1:300.150
So seem the limit of
1:300.100 I set in the mapfile is not so exactly used.
But I'm not able to understand if is a wrong QGIS calculation of scale
value or is a MapServer trouble.
Any hint is welcome
Andrea Peri
qwerty àèìòù
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130213/631584d4/attachment-0001.html>
