[mapserver-users] Photo Viewer
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Thu Feb 14 09:30:16 PST 2013
Steve,
Do you have a sample Mapfile chunk around for this? I can try a test later today . . .
Bobb
Sent: Thursday, February 14, 2013 10:54 AM
To: Basques, Bob (CI-StPaul); Weisbender, Eric; mapserver-users at lists.osgeo.org
Subject: RE: Photo Viewer
I would think it could be done, your extent would be given in pixels. Full extent is given as 0 0 width-1 height-1. Depends if the raster code respects the layer TRANSFORM parameter.
Steve
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Basques, Bob (CI-StPaul)
Sent: Thursday, February 14, 2013 10:34 AM
To: Weisbender, Eric; mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] Photo Viewer
Eric,
Interesting idea. I remember a thread a few years back about something similar being asked.
As far as the geo-referencing part, you can simply use the size of the image as your reference coordinate system for each image. Mapserver is more generally suit towards combining different data into a single output, thus the need for a coordinate system to reference more than one layer.
So, the real question boils down to a technique for fooling MapServer into some sort of projection some how for each image. Let me think on this a bit. I wonder though about setting up something to register images to a location via a loading form which grabs the image size, etc. Then they are put away with the sudo projection assigned to each image at the uploading point.
Bobb
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Weisbender, Eric
Sent: Thursday, February 14, 2013 10:03 AM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] Photo Viewer
I would like to use MapServer as just an unreferenced image viewer for jpgs so I can zoom in and out on the image. Everything I read says that images have to be georeferenced. Any idea or even examples would be greatly appreciated.
Thanks,
Eric Weisbender
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130214/a835ab1b/attachment.html>
