[mapserver-users] Connection to SpatiaLite utilizing SQL
Roman
romat2 at gmail.com
Fri Feb 22 05:10:25 PST 2013
Hi list,
I have a working connection to SpatiaLite
CONNECTION "c:/Temp/test.sqlite"
DATA "Lines"
For certain layers I need to specify connection by SQL. According to
http://mapserver.org/input/vector/sqlite.html I tried this:
DATA "SELECT geometry FROM Lines"
With 6.2.0 stable it does not render specified layer and does not throw any
error.
With development version taken from http://www.gisinternals.com/sdk/ I get
an error "msOGRFileNextShape(): OGR error. Unable to query table
Lines(geometry) for column definitions : no such table: Lines(geometry)."
Geometry column is correctly registered in geometry_columns table and
"ogrinfo test.sqlite Lines -summary" says "Geometry Column = geometry".
Where could be the problem?
Thank you in advance.
Roman
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130222/0c3f25f0/attachment.html>
