[mapserver-users] tips to draw a symbol
Gery
gamejihou at hotmail.com
Tue Feb 26 01:21:09 PST 2013
Hello Håvard,
Thanks for your answer, I tested yesterday in my 5.6 version and it also works well, the problem is that after changing the values during many hours I couldn't set properly the right value to get that "opened v", so I think just doing random changes here and there won't help me to draw well this figure. I was thinking about some tips to draw this image, I think first I should take a piece of paper and draw this image and then take the measurements from it, is this the right, easy way to do it? those values in v-poly were calculated in this way?
Gery
Date: Tue, 26 Feb 2013 00:07:25 -0800
To: gamejihou at hotmail.com
Subject: Re: tips to draw a symbol
Dear Gary,
The v-poly symbol should be OK (I just tested it with
6.2 and 5.6.6). If you want an open V, you should
use only outlinecolor:
STYLE
SYMBOL "v-poly"
SIZE 30
OUTLINECOLOR 0 255 0
END # STYLE
Håvard
On 2/26/2013 12:36 AM, Gery wrote:
> Hello folks,
> I've been trying to draw the attached image but with no luck, I've used
> "v-poly" from http://mapserver.org/mapfile/symbology/construction.html but
> couldn't get the opened "v" effect, could anyone please provide some tips to
> draw such image? I'll appreciate it, thanks in advance.
> Regards,
> Gery
> View this message in context: http://osgeo-org.1560.n6.nabble.com/tips-to-draw-a-symbol-tp5036813.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> [hidden email]
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/tips-to-draw-a-symbol-tp5036813p5036860.html
To unsubscribe from tips to draw a symbol, click here.
NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/tips-to-draw-a-symbol-tp5036813p5036887.html
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130226/658a2249/attachment.html>
