[mapserver-users] GetLegendGraphics don't return correctly the point symbol
thomas bonfort
thomas.bonfort at gmail.com
Tue Jan 8 03:44:24 PST 2013
Do you have a SIZEUNIT or SYMBOLSCALEDENOM set on your layer ?
Try increasing/setting your CLASS->STYLE->SIZEs, and remove the GEOMTRANSFORM
thomas
On 8 January 2013 12:18, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> I have a polygon layer that at some scales try to render with a symbol.
> To do this I define a specific symbol style:
> SYMBOL
> NAME "circlefill"
> TYPE ellipse
> POINTS
> 1 1
> END
> FILLED true
> ANCHORPOINT 0.5 0.5
> END
> And use this in the class definition as here where I put two class one
> with a polygon rendering (when area bigger) and a second class with
> point rendering when area is lower:
> CLASS
> NAME 'area superiore a 1ha'
> EXPRESSION ( ([AREA] >= 1000000) )
> GROUP 'delimitazione zona di vincolo'
> MAXSCALEDENOM 4000100
> MINSCALEDENOM 50100
> STYLE
> COLOR "#F2BAFE80"
> OUTLINECOLOR "#F2BAFE"
> ANTIALIAS false
> END
> END
> CLASS
> NAME 'area inferiore a 1ha'
> EXPRESSION ( ([AREA] < 1000000) )
> MINSCALEDENOM 50100
> STYLE
> GEOMTRANSFORM 'start'
> SYMBOL 'circlefill'
> SIZE 4
> COLOR "#F2BAFEFF"
> ANTIALIAS false
> END
> END
> Unfortunately the getlegendgraphis don't recognize this symbol
> definition and seem to render always using a polygon style (because
> the layer is originally a polygon).
> This is what return the GetLegendGraphics.
> http://web.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmstematici&service=wms&request=GetLegendGraphic&version=1.3.0&format=image/png&SLD_VERSION=1.1.0&layer=rt_tematici.idarch_a_1.rt&scale=60000
> Am I wrong something in the class definitions ?
> Many thx,
> Andrea Peri
> qwerty àèìòù
> mapserver-users at lists.osgeo.org
