[mapserver-users] GetLegendGraphics don't return correctly the point symbol
thomas bonfort
thomas.bonfort at gmail.com
Tue Jan 8 04:58:02 PST 2013
correct, I've just checked and geomtransform handling isn't supported
for legend rendering.
thomas
On 8 January 2013 13:51, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> I try the
> geomtransform centroid
> Unfortunately still the GetLegendGraphics return the
> OOOO
> OOOO
> OOOO
> This is the call sample:
> http://web.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmstematici&service=wms&request=GetLegendGraphic&version=1.3.0&format=image/png&SLD_VERSION=1.1.0&layer=rt_tematici.idarch_a_1.rt&scale=60000
> 2013/1/8 Andrea Peri <aperi2007 at gmail.com>:
>> oh oh. :)
>> I don't know it was existant. It is not in the documentation. :)
>> I try it instantly.
>> 2013/1/8 thomas bonfort <thomas.bonfort at gmail.com>:
>>> then you need geomtransform centroid, no?
>>> On 8 January 2013 13:33, Andrea Peri <aperi2007 at gmail.com> wrote:
>>>> Actually it is returning something like this:
>>>> OOOOOOO
>>>> OOOOOOO
>>>> OOOOOOO
>>>> OOOOOOO
>>>> These seem a polygon filled with many circles internally
>>>> Instead I would like to obtain something like this:
>>>> O
>>>>> what are you trying to obtain ?
>>>>> On 8 January 2013 13:16, Andrea Peri <aperi2007 at gmail.com> wrote:
>>>>>> Hi,
>>>>>> many thx for response.
>>>>>>> Do you have a SIZEUNIT or SYMBOLSCALEDENOM set on your layer ?
>>>>>> No.
>>>>>>> Try increasing/setting your CLASS->STYLE->SIZEs, and remove the GEOMTRANSFORM
>>>>>> I try to removing the geomtransform, but it do disappeared all symbol
>>>>>> (ie polygons lesser then defined area).
>>>>>> But I see something of good try-ing to increase the size and also
>>>>>> adding a lesser than default outline.
>>>>>> ie:
>>>>>> size 6
>>>>>> with 0.1
>>>>>> and leaving the GeomTransform 'start'
>>>>>> It is surely better, but still it seem a polygon filled with many circles.
>>>>>> Instead my rendering is 1 only point for an entire polygon.
>>>>>> This seem not clearly understandable from the returned legend.
>>>>>> This is the result:
>>>>>> Many thx for hints,
>>>>>> Andrea.
>>>>>>> thomas
>>>>>>> On 8 January 2013 12:18, Andrea Peri <aperi2007 at gmail.com> wrote:
>>>>>>>> Hi,
>>>>>>>> I have a polygon layer that at some scales try to render with a symbol.
>>>>>>>> To do this I define a specific symbol style:
>>>>>>>> SYMBOL
>>>>>>>> NAME "circlefill"
>>>>>>>> TYPE ellipse
>>>>>>>> POINTS
>>>>>>>> 1 1
>>>>>>>> END
>>>>>>>> FILLED true
>>>>>>>> ANCHORPOINT 0.5 0.5
>>>>>>>> END
>>>>>>>> And use this in the class definition as here where I put two class one
>>>>>>>> with a polygon rendering (when area bigger) and a second class with
>>>>>>>> point rendering when area is lower:
>>>>>>>> CLASS
>>>>>>>> NAME 'area superiore a 1ha'
>>>>>>>> EXPRESSION ( ([AREA] >= 1000000) )
>>>>>>>> GROUP 'delimitazione zona di vincolo'
>>>>>>>> MAXSCALEDENOM 4000100
>>>>>>>> MINSCALEDENOM 50100
>>>>>>>> STYLE
>>>>>>>> COLOR "#F2BAFE80"
>>>>>>>> OUTLINECOLOR "#F2BAFE"
>>>>>>>> ANTIALIAS false
>>>>>>>> END
>>>>>>>> END
>>>>>>>> CLASS
>>>>>>>> NAME 'area inferiore a 1ha'
>>>>>>>> EXPRESSION ( ([AREA] < 1000000) )
>>>>>>>> MINSCALEDENOM 50100
>>>>>>>> STYLE
>>>>>>>> GEOMTRANSFORM 'start'
>>>>>>>> SYMBOL 'circlefill'
>>>>>>>> SIZE 4
>>>>>>>> COLOR "#F2BAFEFF"
>>>>>>>> ANTIALIAS false
>>>>>>>> END
>>>>>>>> END
>>>>>>>> Unfortunately the getlegendgraphis don't recognize this symbol
>>>>>>>> definition and seem to render always using a polygon style (because
>>>>>>>> the layer is originally a polygon).
>>>>>>>> This is what return the GetLegendGraphics.
>>>>>>>> Am I wrong something in the class definitions ?
>>>>>>>> Many thx,
>>>>>>>> Andrea Peri
>>>>>>>> qwerty àèìòù
>>>>>>>> _______________________________________________
>>>>>>>> mapserver-users mailing list
>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>>>> Andrea Peri
>>>>>> qwerty àèìòù
>>>> Andrea Peri
>>>> qwerty àèìòù
>> Andrea Peri
>> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
