[mapserver-users] Newer version of Freetype causing font rendering problems
thomas bonfort
thomas.bonfort at gmail.com
Fri Jan 11 04:23:26 PST 2013
Fiona,
If this important for you, I'd suggest you investigate what changes in
freetype are triggering this different rendering (it might be options
passed to the freetype api, or configuration/compile time options to
add/remove). Once you have nailed down the change, feel free to follow
up to this list and/or to a github issue so we can update the
mapserver codebase if necessary.
regards,
thomas
On 11 January 2013 12:01, Fiona Hemsley-Flint <fiona.flint at ed.ac.uk> wrote:
> In an update to this issue
> (http://lists.osgeo.org/pipermail/mapserver-users/2012-December/073844.html),
> we have just found that the older version of Freetype (2.3.9) is no longer
> available form the repository we got it from, which might mean that it will
> become obsolete in time, and therefore any new installs of Mapserver will
> have a text rendering problem if they are using the new version of Freetype
> and this issue remains unresolved.
> Are there any plans from the Mapserver end to look into this problem?
> Thanks again,
> Fiona
> Dr Fiona Hemsley-Flint
> EDINA National Data Centre,
> University of Edinburgh
> +44(0)131 6514462
> The University of Edinburgh is a charitable body, registered in
> Scotland, with registration number SC005336.
> mapserver-users at lists.osgeo.org
