[mapserver-users] apache module - mapserver
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Fri Jan 18 01:40:56 PST 2013
> I noticed during compilation of mapserver 6.2 that there is
> an apache module as well.
Please note that the module currently has limited functionality.
> However, which parameters do i need to pass to httpd.conf for
> the module to work correctly? How can I properly test it when
> its configured as module? Calling /mapserver or /mapserv
> didn't do the trick for me.
You need to configure a <Location> and set the Mapfile directive, f.e.:
<Location "/mapserver">
Mapfile "/path/to/mapfiles/mapfile.map"
</Location>
Currently you need to create such a configuration for every MAP file you
want to publish.
