[mapserver-users] RE RE runtime-substitution on GetFeatureInfo request
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Tue Jan 22 10:27:46 PST 2013
http://mapserver.org/cgi/runsub.html#validation
Because runtime substitution affects potentially sensitive areas of your
mapfile such as database columns and filenames, it is mandatory that you
use pattern validation (since version 6.0)
Whatever you are trying to do it won't work until you have a validation
block
Andrea Peri <aperi2007 at gmail.com>@lists.osgeo.org
Envoyé par : mapserver-users-bounces at lists.osgeo.org
2013-01-22 13:05
A
mapserver-users at lists.osgeo.org
cc
Objet
[mapserver-users] RE runtime-substitution on GetFeatureInfo request
thx for response.
No I not define any validation block.
I'm try to test if it work before to apply a validation block.
I try to apply a FILTER like this:
    FILTER "VOLO_N = 3 and (FILESTAMPE like '%IDTPN%' )"
the goal is to obtain that on a GetFeatureInfo request where the
response without the filter will return three or four objects,
and identifiables with id001,id002,id003 and id004, passing a
parameter like ..&idtpn=id001
it will return only one object.
also I try to apply a default value like this:
    METADATA
      'default_idtpn' '%'
to avoid that when I do noone idtpm parameter it will return an empty
recordset.
Thx
Andrea.
>What kind of trouble exactly?
>Do you have a Validation block in your layer definition?
>>2013-01-21 19:26
Andrea Peri
qwerty àèìòù
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130122/5e435163/attachment.htm>
More information about the MapServer-users mailing list
