[mapserver-users] WFS GetFeature with filter for multiple layers
Arjen de Korte
arjendk at gmx.net
Wed Jan 23 01:18:16 PST 2013
Hi Steve,
Yes, for now I (my client) is stuck to this version, so a workaround (or
accepting that it can't be done) is the only option at the moment. Has
this been solved in newer versions?
Kind regards,
Arjen.
On Tue, Jan 22, 2013, at 20:15, Lime, Steve D (DNR) wrote:
> Are you stuck running such an old version?
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Arjen de
> Korte
> Sent: Tuesday, January 22, 2013 10:45 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] WFS GetFeature with filter for multiple layers
> Hi all,
> I'm having a problem with Mapserver 5.2.1 and WFS GetFeature requests:
> when I do a GetFeature request with an OGC filter for more than one
> layer, I only get results for the first layer. I found a description of
> the issue here: https://github.com/mapserver/mapserver/issues/3584. It
> says the issue can be worked around by listing a separate filter for each
> layer, but I can't work out a way to do this.
> My original request looks like this:
> http://myserver.com/cgi-bin/mapserv.exe?map=mymapfile.map&Service=WFS&Request=GetFeature&TypeName=layer1,layer2&Version=1.0.0&Filter=<ogc:Filter
> xmlns:ogc="http://www.opengis.net/ogc"><ogc:Intersects><ogc:PropertyName/><gml:Polygon
> xmlns:gml="http://www.opengis.net/gml"><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates
> decimal="." cs="," ts=" ">89760.045356755,436071.75388938
> 89762.029730683,436071.75388938 89762.029730683,436073.7382633
> 89760.045356755,436073.7382633
> 89760.045356755,436071.75388938</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></ogc:Intersects></ogc:Filter>
> ...returning only results for layer1.
> I've tried repeating the exact same filter like:
> xmlns:ogc="http://www.opengis.net/ogc"><ogc:Intersects> ...
> </ogc:Intersects><ogc:Intersects> ... </ogc:Intersects></ogc:Filter>
> and
> </ogc:Intersects></ogc:Filter>,<ogc:Filter><ogc:Intersects> ...
> ...but the first returns the same: only results for layer1, and the
> second returns an error.
> What is the correct way to list multiple filters, or is there another
> solution to work around this limitation?
> Thanks!
> Kind regards,
> Arjen.
