[mapserver-users] I've been accused of not using things the way they were intended, but . . . can a getcapabilities request be run through the MapServer TEMPLATE for output?
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jan 29 10:39:29 PST 2013
Bob,
Seems like this is trivial to do with a Perl wrapper.
Make a Perl script that makes a mapserver GetCapabilities request and
suck that into XML and reformat how you like.
-Steve W
On 1/28/2013 12:29 PM, Basques, Bob (CI-StPaul) wrote:
> Brent,
> Pretty much as you describe . . .
> I want a list of layers but in my own form (Not OGC), specifically, I’ve
> used a TEMPLATE in the past to output LISP code that I can run in
> AutoCAD as an executable, sort of a poor man’s importer for raster
> images. This has been working for over a decade now, but each layer has
> to be set up individually in the current architecture. The next leap
> forward would be to read a layer list from (??) the web as a service,
> and have the list pop out as a LISP construct for use in AutoCAD for
> choosing of layers. Right now we hand build a somewhat static dialog in
> AutoCAD to do this.
> The bigger goal, is to be able to add to the MapServer / GeoMoose data
> stores and have the new content appear automatically in the AutoCAD
> session as a new list item. I can write a intermediate helper app to
> read our GeoMoose MapBook for example and then send back the AutoLisp
> construct, but I was wondering if there were a way around this
> intermediate piece, but with a TEMPLATING capability. In the end it’s
> probably more flexible to go the helper app route, but . . .???
> Bobb
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Monday, January 28, 2013 11:20 AM
> *To:* Basques, Bob (CI-StPaul)
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] I've been accused of not using things
> Bob,
> I'm not sure I understand what you are trying to do (on the mapserver
> side or the Autocad side!). Do you want mapserver to return a list of
> layers (when sent an OGC GetCapabilities or equivalent non-standard
> request) in a format of your choosing, similar to the way
> template-driven output
> (http://mapserver.org/output/template_output.html) returns feature info
> in a custom format ?
> Best Regards,
> Brent Fraser
> On 1/28/2013 8:02 AM, Basques, Bob (CI-StPaul) wrote:
> All,
> So, I was thinking about adding support for Raster pulling from
> AutoCAD work sessions directly. We’ve had this capability in place
> for a number of years using MapServer calls to each layer
> individually. I’m researching the idea of rebuilding the importing
> routines but with the added functionality of reading a
> getcapabilities call to flesh out the listing of the available
> layers in the server. Yes I know there is a FDO provider in
> AutoCAD, but that is only available in Map and Civil, not regular
> AutoCAD (or ARCH, still??) Versions which we also support.
> First thought was to build a XML parser as a separate web service,
> that would make the call(s) to mapserver. This would output the
> data in a AutoCAD readable form such as AutoLISP. Another thought
> was to read our GeoMoose MapBook, an XML file, for listing out the
> available layers behind MapServer, this has the advantage of using
> our existing tools and methods for access the data and it would be
> completely automated with the GeoMoose MapBook becoming the master
> data catalog.
> Whatever comes of this will also be eventually morphed into a
> Feature importer (WFS, etc) as well, which we also already have in
> place, but in a manner that could be improved.
> So, back to the question, can a XML return from MapServer be passed
> through a TEMPLATE to change the output?
> Thanks
> Bobb
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
