[mapserver-users] PHP Clustering algo / library to replace Google clusters
David Quinn
daithiquinn at gmail.com
Wed Jan 30 13:02:16 PST 2013
I doubt it can be used in it's current form as this is an extension for
postgres.
I installed it into postgres and used it that way. Perhaps someone has
written this for MySQL too.
-David
On Wed, Jan 30, 2013 at 3:54 PM, Ivan Cardenas <ivanc at kestrel-tech.com>wrote:
> Thanks David,
> can this be adapted to MYSQL to your knowledge?
> Thanks,
> Ivan
> On Wed, Jan 30, 2013 at 2:51 PM, David Quinn <daithiquinn at gmail.com>wrote:
>> I'ved used the kmeans-postgresql clustering package to do this. A good
>> example of how to use it is give here:
>> http://gis.stackexchange.com/questions/11567/spatial-clustering-with-postgis
>> -David
>> On Wed, Jan 30, 2013 at 3:38 PM, Ivan Cardenas <ivanc at kestrel-tech.com>wrote:
>>> Is there a cluster algorithm library routine for PHP to replace the
>>> Google Maps API geotag icon clustering? These are the aggregations of many
>>> points into one point with the number of points on the circular icon.
>>> Thanks!
>>> Ivan Cardenas | Technical Director
>>> ivanc at kestrel-tech.com | Kestrel Technology Group
>>> +1-281-242-6349 main | +1-281-491-0379 fax
>>> +1-713-899-1415 US mobile
>>> CONFIDENTIALITY NOTICE
>>> This electronic mail transmission is confidential, may be privileged and
>>> should be read or retained only by the intended recipient. If you have
>>> received this transmission in error, please immediately notify the sender
>>> and delete it from your system.
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130130/0cd899a6/attachment.html>
