[mapserver-users] [TinyOWS] TinyOWS 1.1.0 and the old good axis order trouble
Martin Kofahl
martin.kofahl at gmail.com
Thu Jan 31 14:22:40 PST 2013
Hi Jukka,
the mapaxisorder.csv was introduced with the axis order requirements of
WMS 1.3.0/INSPIRE and is still a poor workaround to get things working.
Accordning to [1] proj4 now supports an +axis parameter. Using the epsg
file with +axis seems quite worthwhile to me, much better than an own
list of codes. However, the epsg file shipped with proj4 4.8.0 doesn't
look complete regarding +axis. I'll try to get an answer from the proj
list.
Martin
[1] http://trac.osgeo.org/proj/wiki/GenParms
> Hi,
> Mapserver seems to rely on this list of coordinate systems with
> reversed axis order:
> https://github.com/mapserver/mapserver/blob/master/mapaxisorder.csv
> Because TinyOWS lives so close to Mapserver perhaps they could utilize
> the same list? It would be nice if Mapserver WFS and TinyOWS WFS
> would have the same understanding about the axis order.
> -Jukka-
> Rahkonen Jukka wrote:
> Hi Olivier,
> Sorry for the late response. I analyzed finally what axis order
> alternatives the srs_wkt field in the spatial_ref_sys table contains
> and the situation is a bit more complicated than you have believed.
> This is the result of a SELECT DISTINCT query
> 1) AXIS[""Easting"",EAST],AXIS[""Northing"",NORTH]]"
> 2) AXIS[""X"",EAST],AXIS[""Y"",NORTH]]"
> 3) AXIS[""Northing"",NORTH],AXIS[""Easting"",EAST]]"
> 4) AXIS[""X"",NORTH],AXIS[""Y"",EAST]]"
> 5) AXIS[""Y"",EAST],AXIS[""X"",NORTH]]"
> 6) AXIS[""X"",SOUTH],AXIS[""Y"",WEST]]"
> 7) AXIS[""Y"",NORTH],AXIS[""X"",EAST]]"
> 8) AXIS[""E(X)"",EAST],AXIS[""N(Y)"",NORTH]]"
> 9) AXIS[""x"",NORTH],AXIS[""y"",EAST]]"
> 10) AXIS[""Easting"",UNKNOWN],AXIS[""Northing"",UNKNOWN]]"
> 11) AXIS[""none"",NORTH],AXIS[""none"",EAST]]"
> 12) AXIS[""X"",UNKNOWN],AXIS[""Y"",UNKNOWN]]"
> 13) AXIS[""Northing"",UNKNOWN],AXIS[""Easting"",UNKNOWN]]"
> My conclusions:
> Must not be flipped: 1, 2, 8
> Must be flipped: 3, 4, 9
> Probably should not be flipped: 10, 12
> Probably should be flipped: 11, 13
> No idea: 5, 6, 7
> The most important system for me is EPSG:3067 and it has the WKT as in
> alternative 1: AXIS[""Easting"",EAST],AXIS[""Northing"",NORTH]]"
> -Jukka Rahkonen-
> Lähettäjä:mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Olivier
> Courtin
> Lähetetty: 18. joulukuuta 2012 9:10
> Vastaanottaja: Mapserver-Users (mapserver-users at lists.osgeo.org)
> Aihe: Re: [mapserver-users] [TinyOWS] TinyOWS 1.1.0 and the old good
> axis order trouble
> On Mon, Dec 17, 2012 at 11:16 AM, Rahkonen Jukka
> <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi Jukka,
> Nice to see you again here :)
> I have been running TinyOWS r558 for quite a long time because it is
> dealing almost right with the axis order of the projections I am
> commonly using. Now I had a fast try with the current TinyOWS 1.1.0
> version but unfortunately I realized that it is doing wrong thing by
> flipping the axis with urn:ogc:def:crs:EPSG::3067.
> On this topic we will not make any progress, without a regression
> test.
> (OGC CITE don't cover this issue)
> Could you provide from a single point stored in the database,
> requests and answers awaited ?
> I could also try to write it by myself too,
> but will definitly need you to read it back,
> for all eastern stuff...
> What is the logic that TinyOWS is using when it decides
> whether the axis should be flipped or not for WFS 1.1.0?
> Mainly 2 factors, as i recall:
> - if it's SRS or CRS (meaning EPSG:xxxx or
> urn:ogc:def:crs:EPSG::xxxx)
> - if SRTEXT contain both AXIS["X",NORTH]] and AXIS["Easting",EAST]]
> Olivier
More information about the MapServer-users
