[mapserver-users] Defining Field Types in WFS
Burgholzer, Robert (DEQ)
Robert.Burgholzer at deq.virginia.gov
Fri Jul 12 07:44:32 PDT 2013
We are having trouble with our WFS service, trying to define data field types as Numeric. Our mapserver version is 5.6.3. Currently, our field types all come out as String when viewed in ArcGIS, and when we try to set the field to a Real type, using the syntax shown in Ex 1 the service breaks, Ex 2 shows the working layer, and Ex 3 shows the full, working layer definition.
Any help would be most appreciated,
r.b.
Ex 1 - BREAKS the Service:
METADATA
"wfs_title" "Water Supply Plan System Information Test" ## REQUIRED
"wfs_srs" "EPSG:4326" ## REQUIRED
"gml_featureid" "system_nid" ## REQUIRED
"gml_include_items" "all" ## Optional (serves all attributes for layer)
"wfs_enable_request" "*"
"wfs_version" "1.0.0"
"gml_current_mgy_type" "Real"
END
Ex 2 - WORKS but gives all type String
METADATA
END
Ex 3 - FULL Layer definitions:
LAYER
NAME wsp_system_info_test
METADATA
END
#GROUP vwuds_max
CONNECTIONTYPE postgis
CONNECTION "host=deq3.bse.vt.edu user=wsp_ro password=314159 dbname=drupal715"
TYPE POINT
STATUS DEFAULT
DUMP TRUE
DEBUG ON
DATA "the_geom FROM (select * from wsp_system_locations ) AS foo USING UNIQUE system_nid"
#FILTER "leapyear <> true"
TEMPLATE drought.html
#MINSCALE 1000
#MAXSCALE 50000
CLASS
SYMBOL 'circle'
SIZE 11
NAME "precip_nml"
COLOR 245 245 245
BACKGROUNDCOLOR 245 245 245
OUTLINECOLOR 0 0 0
END
TOLERANCE 10
PROJECTION
# EPSG SRID = 4326
"init=epsg:4326"
END
END
Robert Burgholzer
Surface Water Modeler
Virginia DEQ Office of Surface and Ground Water Supply
804-869-3066
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130712/d9168fa1/attachment.html>
