[mapserver-users] Ogrtileindex troubles with MS 6.2 on Linux
    Rahkonen Jukka
    jukka.rahkonen at mmmtike.fi
    Wed Jul 17 01:16:22 PDT 2013
I have had some troubles with using ogrtileindex on Linux (CentOS) with Mapserver 6.2.1.  I faced two dictinct issues.
1) Uppercase/lowercase trouble with file names of the source vectors when using the MS native connection.
My shapefiles had names like "MM26P3CP.SHP". I created an ogrtindex file from those and used the native connection as
TILEINDEX "ogrtindextest.shp,0"
Result was an error and Mapserver told that it could not open file MM26P3CP.SHP,0. A desperate trial revealed me that if I renamed all my source shapefiles to lowercase characters the native connection started to work.
2) Http 503 server error when using OGR connection and SLD_BODY in the WMS GetMap request.
The original source files with uppercase characters in the file names work in stardard WMS usage by using OGR connection instead of the native one
CONNECTIONTYPE OGR
However, our application is sending WMS GetMaps with SLD_BODY parameter and with OGR connection the result is always a server error.
I have made a test on Windows with MS4W and Mapserver version 6.3-dev and I can not reproduce those errors. I prepared a complete zip file from my MS4W test set-up with mapfile, couple of original shapefiles, corresponding ogrtindex file and GetMap request with SLD_BODY and it is downloadable from here
http://latuviitta.org/downloads/mapserver_62_trouble_with_ogrtindex.zip
As I said there are no troubles with MS4W but on our Linux server the ogrtindex does not work with native connection and with OGR connection using SLD_BODY in the GetMap request leads to server error.
The problem is not acute for us anymore because I have renamed the original shapefiles to lowercase and now we can use the native tindex connection and SLD_BODY works. However, it took so many hours to to analyze the problem that I think it is worth reporting my findings here.
-Jukka Rahkonen-
More information about the MapServer-users
