[mapserver-users] A problem about setting transparent raster layer.
Guo YU
yuguo365 at gmail.com
Thu Jul 18 03:08:12 PDT 2013
Thanks Thomas,
Set the Opacity on the Openlayer level works.
But on the Mapserver side, those changes still doesn't work. Anyway,
the problem is solved. Thanks.
On Thu, Jul 18, 2013 at 10:54 AM, thomas bonfort
<thomas.bonfort at gmail.com>wrote:
> (please keep your messages on the list)
> change pc256 to rgba in your mapfile.
> add format:"image/png" to your openlayers options (same level as
> alpha:true, which is not needed).
> That said, there still very well could be a bug in the raster
> classification code as opacity wasn't a first class citizen back in
> the GD days....
> as for client side opacity: add opacity:0.5 to your javascript (same
> level as isBaseLayer)
> thomas
> On 18 July 2013 11:46, Guo YU <yuguo365 at gmail.com> wrote:
> > Dear Thomas,
> > Thanks for your reply.
> > The mapserver I am using is from MS4W, so it is MS4W Setup
> Installer
> > v3.0.6 (May 26, 2012).
> > What Do you mean by use opacity at the client level? Where should
> I
> > set it?
> > I changed the driver from GD to AGG, but nothing changed.
> > OUTPUTFORMAT
> > NAME "png"
> > MIMETYPE "image/png"
> > DRIVER "AGG/PNG"
> > EXTENSION "png"
> > IMAGEMODE "PC256"
> > TRANSPARENT on
> > END
> > On Thu, Jul 18, 2013 at 10:38 AM, thomas bonfort <
> > wrote:
> >> Guo,
> >> Why not use opacity at the client level only ?
> >> That said, this does seem like a bug. Can you specify which mapserver
> >> version you are using, and which outputformat your are using (and if
> >> you are using a GD one, try switching to AGG).
> >> thomas
> >> On 18 July 2013 11:28, Guo YU <yuguo365 at gmail.com> wrote:
> >> > Dear All,
> >> > Since I need to show the code and figures about my problem, I
> post
> >> > it
> >> > on the Stack Exchange.
> >> > I got problem with Setting a Transparent Raster Layer and then show
> this
> >> > layer though OpenLayer.
> >> > Here is the link :
> http://gis.stackexchange.com/questions/66388/how-to-make-a-raster-layer-transparent-via-mapserver
> >> > Thanks for your time.
> >> > YU Guo
> >> > MSc. Hydroinformatics and Water Management
> >> > Email: yuguo365 at gmail.com
> >> > Phone: +33 668 195803
> >> > _______________________________________________
> >> > mapserver-users mailing list
> >> > mapserver-users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > YU Guo
*YU Guo
*Email*: *yuguo365 at gmail.com*
*Phone*: +33 668 195803
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130718/fd839646/attachment.html>
