[mapserver-users] Using SIZEUNITS in MapFile with OpenLayers: works being served as WMS Layer, but not OpenLayers.Layer.MapServer
David Pardy
dpardy87 at gmail.com
Tue Jul 23 10:23:56 PDT 2013
Hello, I've been struggling on this issue and it seems SIZEUNITS is not
being recognized correctly without using WMS (which, really should not be a
factor. It should be simpler not using WMS).
SIZEUNITS units default is pixels. I am trying to use miles. In my html
file I have
var cust = new OpenLayers.Layer.MapServer("POIs", "
http://192.168.2.164/cgi-bin/mapserv.exe", {map:
"/data2/html/html2/david_POIs4.map", layers: ['POIs']}, {singleTile: true}
My Mapfile layer (POIs) consists of this:
LAYER
NAME POIs
DEBUG 5
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION 'PointsOfInterest_Latest.db'
DATA 'POIs'
STATUS ON
SIZEUNITS miles
LABELITEM "name"
CLASS
STYLE
SYMBOL 'Airport'
COLOR 8 29 118
WIDTH 2
SIZE 200
END
#STYLE
# SYMBOL 'City'
# COLOR 8 29 118
# SIZE 6
#END
LABEL
FONT "andalewt"
TYPE truetype
ENCODING "UTF-8"
MINSIZE 9
MAXSIZE 9
POSITION AUTO
PARTIALS FALSE
COLOR 8 29 118
OFFSET 1 1
PRIORITY 10
BUFFER 0
END # LABEL
END
PROJECTION
"proj=latlong"
"ellps=WGS84"
"datum=WGS84"
END
END
I have the SIZE set to 200 so the radius will be 100 miles. As you can see
I commented out the second symbol commented out for now: just trying to get
something working.
It also seems that whether the SIZE value is 200 or 10 (any number,
really), the circles are still huge: more or less taking up the whole map.
Whether the value is 200 or 10 miles (and working correctly), these circles
should not be very big on the farthest zoom level out in a standard
OpenLayers map.
I posted two pictures here to give you an idea of what I'm talking about:
http://imgur.com/a/DhK3Y
The first picture is correct: the data is being served as a WMS layer.
The second picture is incorrect: the data is being served as a MapServer
layer.
I do not understand how removing WMS and instead using a MapServer layer
for OL is generating behavior such as this.
Any input on this issue is appreciated.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130723/98eb88de/attachment.html>
