[mapserver-users] How set transparency on a changed color raster
    Andrea Peri
    aperi2007 at gmail.com
    Mon Jul 29 01:44:12 PDT 2013
I have a black/white dataset with many rasters.
I will use all of them with a catalog and set usually the white as
transparency to see all as it was an unique raster.
Now I have the nee to serve it also with changing the black to white.
But I need to distinguish between the real white that should still be
transparency and the white caming from black original pixel that should not
be transparency.
To allow this I'm try-ing to change
the white to grey
and
black to white
and also I try to set the transparency to the grey color.
This is what I have do in the mapfile:
    TYPE raster
    TILEINDEX '/path-to-catalog/index_tiled'
    PROCESSING "BANDS=1"
    PROCESSING "NODATA=255"
    METADATA
    END
    OFFSITE 164 164 164
    OPACITY 100
    CLASSITEM "[pixel]"
    CLASS
      EXPRESSION ([pixel] = 0)
      STYLE
        COLOR 164 164 164
      END
    END
    CLASS
      EXPRESSION ([pixel] = 1)
      STYLE
        COLOR 255 255 255
      END
    END
I set the offsite to the 164 164 164 but it don't seem to understand or use
it.
It seem using always the white original color.
Any hint is welncome,
thx,
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130729/1960eba6/attachment.htm>
More information about the MapServer-users
