[mapserver-users] Oracle access using CONNECTIONTYPE PLUGIN
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Tue Jul 30 00:28:13 PDT 2013
On our site we use
CONNECTIONTYPE oraclespatial
CONNECTION '<username>/<password>@<service_name>'
and in tnsnames.ora:
<instance> =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP)(HOST = <hostname>)(PORT = <port>))
(CONNECT_DATA =
(SERVER = DEDICATED)
(SERVICE_NAME = <service_name>)
Although you go with the plugin method I would guess it finally uses the same connection string as the integrated driver.
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag
> von Nelly.Howind at kivbf.de
> Gesendet: Dienstag, 30. Juli 2013 09:07
> An: mapserver-users at lists.osgeo.org
> Betreff: [mapserver-users] Oracle access using CONNECTIONTYPE PLUGIN
> Hi,
> I try to access an oracle DB using following entry in mapfile:
> PLUGIN "msplugin_oracle.dll"
> CONNECTION "localhost,port:1521,<DBname>,<user>,<password>"
> DATA "GEOM FROM WSG USING SRID 31467"
> I installed Oracle 11g locally on Windows 2008 R2 64 bit
> system and can connect to it via Net Manager or SQL Developer.
> I use a compiled mapserver release MSVC2010 Win 64
> downloaded from http://www.gisinternals.com/sdk/
> <http://www.gisinternals.com/sdk/> , which works fine with
> file based geodata.
> Now I get an error message ORA-01005 (null password given;
> logon denied), but I set password correctly.
> Has anybody an idea, what I am making wrong? Has connection
> string using oracle another syntax?
> Thanks in advance
> Nelly
> Kommunale Informationsverarbeitung Baden-Franken
> Nelly Howind
> Kommunale Dienstleistungen
> Geoinformation und Umwelt
> Betriebsstätte Karlsruhe
> Pfannkuchstraße 4, 76185 Karlsruhe
> Fon: +49 721 9529 351
> Fax: +49 721 9529 500351
> E-Mail: Nelly.Howind at kivbf.de
> Internet: http://www.kivbf.de
> ________________________________
> Zweckverband
> Fon +49 721 9529 0, Fax +49 721 9529 120
> Verbandsvorsitzender: LR Hämmerle
> Hauptgeschäftsführer: William Schmitt
> Kommunales Rechenzentrum Baden Franken GmbH
> Handelsregister des Amtsgerichts Mannheim Nr. HRB 109683
