[mapserver-users] compiling mapcache on windows error.
Hishan Melanga
hishanm at gmail.com
Sun Jun 2 01:02:45 PDT 2013
I am trying to compile mapcache on windows. By looking at
http://mapserver.org/mapcache/install.html#windows-instructions. In
nmake.opt file I changed line 33 to MAPCACHE_BASE =
C:\Users\MWH\Desktop\mapcache
and line 92 to WINSOCK_LIB ="C:\Program Files\Microsoft
SDKs\Windows\v6.0A\Lib\WS2_32.Lib"
After that I executed the command nmake /f Makefile.vc But this command
gives me an error telling
C:\Users\MWH\Desktop\mapcache\include\mapcache.h(37) : fatal error C1083:
Cannot
open include file: 'mapcache-config.h': No such file or directory
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio
9.0\
VC\BIN\cl.EXE"' : return code '0x2'
Stop.
But inside my C:\Users\MWH\Desktop\mapcache\include\ directory there is '
mapcache-config.h.in file. Why is this happening? Is there any other
configuration parameter I have to change? By the way I have installed
Visual Studio 2008 in Windows 8. I attached my nmake.opt file for you to
look at. Please indicate the places that I have to change.
හිෂාන් මෙලංග | Hishan Melanga <http://hishanmelanga.blogspot.com/>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130602/90fa2973/attachment.html>
# nmake.opt - mapcache
# Uncomment the following if you are building for 64-bit windows
# (x64). You'll need to have PATH, INCLUDE and LIB set up for 64-bit
# compiles.
WIN64=YES
# Check compiler version given in command line
# nmake -f makefile.vc MSVC_VER=xxxx
# 1310 = 7.1 (2003) 1400 = 8.0 (2005)
!IFNDEF MSVC_VER
#assume msvc 7.1
MSVC_VER=1500
!ENDIF
# File locations and where to install things
# If you are using the MapServer Build Kit, almost everything should be
# relative to this directory throughout this option file.
# Set the following to point to the directory adjacent to the dependent libs.
!IFNDEF MAPCACHE_BASE
MAPCACHE_BASE = C:\Users\MWH\Desktop\mapcache
#MAPCACHE_BASE = .
!ENDIF
# Optmization, debug, and related compile flags.
!IF $(MSVC_VER) == 1400
# Optimized, with using MSVCRT.
OPTFLAGS = /nologo /Ox /MD $(WARNING_LEVEL) $(DEBUG) /EHsc /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE
# Debug with MSVCRT
#OPTFLAGS = /nologo /Zi /MD $(WARNING_LEVEL) $(DEBUG) /EHsc /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE
#LDFLAGS = /NODEFAULTLIB:msvcrt /NODEFAULTLIB:libcd /DEBUG
!ELSE
# Debug with MSVCRT
#OPTFLAGS = /nologo /Zi /MDd $(WARNING_LEVEL) $(DEBUG) /EHsc
!ENDIF
# Set the Warning level for the compiler (defaults to W1)
WARNING_LEVEL=/W3
# Debugging Options
#NEED_NONBLOCKING_STDERR=-DNEED_NONBLOCKING_STDERR
ENABLE_STDERR_DEBUG=-DENABLE_STDERR_DEBUG
# Set the linker debug option
LDEBUG=/debug
# DEBUG Build flags
# Set the DEBUG flag if you wish to make a debug build
DEBUG=/DDEBUG
# APR: Apache Protable Runtime library
APR_DIR = $(MAPCACHE_BASE)\..\apr-1.4.5
APR_ICONV_DIR = $(MAPCACHE_BASE)\..\apr-iconv-1.2.1
APR_UTIL_DIR = $(MAPCACHE_BASE)\..\apr-util-1.4.1
# APACHE HTTPD (Only required for apache module)
APACHE_DIR=$(MAPCACHE_BASE)\..\httpd-2.2.22
# PNG support
PNG_DIR=$(MAPCACHE_BASE)\..\libpng-1.5.10
ZLIB_DIR=$(MAPCACHE_BASE)\..\zlib-1.2.7
ZLIB_INC=-I$(ZLIB_DIR)
CURL=-DUSE_CURL
CURL_DIR=$(MAPCACHE_BASE)\..\curl-7.25.0
WINSOCK_LIB ="C:\Program Files\Microsoft SDKs\Windows\v6.0A\Lib\WS2_32.Lib"
JPEG_DIR=$(MAPCACHE_BASE)\..\jpeg-8d
JPEG_INC = -I$(JPEG_DIR)
# SQLite3 Support
# Uncomment, and update accordingly.
SQLITE_DEF=-DUSE_SQLITE
SQLITE_DIR=$(MAPCACHE_BASE)\..\libspatialite-amalgamation-2.3.1
# TIFF Support
TIFF_DEF=-DUSE_TIFF -DUSE_TIFF_WRITE
TIFF_DIR=$(MAPCACHE_BASE)\..\libtiff-4.0.1
# GEOTIFF Support
GEOTIFF_DEF=-DUSE_GEOTIFF
GEOTIFF_DIR=$(MAPCACHE_BASE)\..\libgeotiff-svn-05232012
# FastCGI Support
FCGI_DEF=-DUSE_FASTCGI
FCGI_DIR=$(MAPCACHE_BASE)\..\fcgi-2.4.0
# GDAL/OGR Support
#GDAL_DEF=-DUSE_GDAL
#GDAL_DIR=$(MAPCACHE_BASE)\..\gdal-trunk
# GEOS Support
#GEOS_DEF=-DUSE_GEOS
#GEOS_DIR=$(MAPCACHE_BASE)\..\geos-3.3.7
# Berkeley DB Support
BDB_DEF=-DUSE_BDB
BDB_DIR=$(MAPCACHE_BASE)\..\berkeley-db-5.3.21
# Section II: Mapserver Rendering Configuration
# Section VI: Support Libraries.
# REGEX Libary
# VC++ does not include the REGEX library... so we must provide our one.
# The following definitions will try to build GNU regex-0.12 located in the
# regex-0.12 sub-directory.
# If it was not included in the source distribution, then you can get it from:
# ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz
# Provide the full path to the REGEX project directory
# You do not need this library if you are compiling for PHP mapscript.
# In that case the PHP regex library will be used instead
REGEX_DIR=$(MAPCACHE_BASE)\..\regex-0.12
# Set the png support libaries
!IFDEF PNG_DIR
!IFNDEF PNG_LIB
PNG_LIB=$(PNG_DIR)\projects\visualc71\Win32_LIB_Release\libpng.lib $(ZLIB_DIR)/contrib/vstudio/vc9/x86/ZlibDllRelease/zlibwapi.lib
!ENDIF
PNG_INC=-I$(PNG_DIR)
!ENDIF
CURL_INC = -I$(CURL_DIR)/include
CURL_LIB = $(CURL_DIR)/lib/libcurl_imp.lib
!IFDEF JPEG_DIR
JPEG_LIB=$(JPEG_DIR)/libjpeg.lib
!ENDIF
!IFDEF SQLITE_DIR
SQLITE_LIB=$(SQLITE_DIR)\lib\spatialite_i.lib
SQLITE_INC=-I$(SQLITE_DIR)\include
!ENDIF
!IFDEF TIFF_DIR
TIFF_LIB=$(TIFF_DIR)\libtiff\libtiff_i.lib
TIFF_INC=-I$(TIFF_DIR)\libtiff
!ENDIF
!IFDEF GEOTIFF_DIR
GEOTIFF_LIB=$(GEOTIFF_DIR)\geotiff_i.lib
GEOTIFF_INC=-I$(GEOTIFF_DIR) -I$(GEOTIFF_DIR)\libxtiff
!ENDIF
FCGI_LIB=$(FCGI_DIR)\libfcgi\Release\libfcgi.lib
FCGI_INC=-I$(FCGI_DIR)\include
!IFDEF GDAL_DIR
GDAL_INC = -I$(GDAL_DIR)/gcore -I$(GDAL_DIR)/alg -I$(GDAL_DIR)/ogr -I$(GDAL_DIR)/port
GDAL_LIB = $(GDAL_DIR)/gdal_i.lib
!ENDIF
!IFDEF GEOS_DIR
GEOS_LIB=$(GEOS_DIR)/src/geos_c_i.lib
GEOS_INC=-I$(GEOS_DIR)/include -I$(GEOS_DIR)/capi
!ENDIF
!IFDEF BDB_DIR
BDB_LIB=$(BDB_DIR)/build_windows/Win32/Release/libdb53.lib
BDB_INC=-I$(BDB_DIR)/build_windows
!ENDIF
# Section VII: Variable Setup
# Should not need to be updated.
MAPCACHE_LIB = mapcache.lib
MAPCACHE_INC= -I$(MAPCACHE_BASE)\include
#APR
APR_INC=-I$(APR_DIR)\include -I$(APR_ICONV_DIR)\include -I$(APR_UTIL_DIR)\include
#APR_LIB=$(APR_DIR)/lib/apr-1.lib $(APR_DIR)/lib/aprutil-1.lib $(APR_DIR)/lib/libapr-1.lib $(APR_DIR)/lib/libaprutil-1.lib
#APR_LIB=$(APR_DIR)/LibR/apr-1.lib $(APR_DIR)/Release/libapr-1.lib $(APR_ICONV_DIR)/LibR/apriconv-1.lib $(APR_UTIL_DIR)/LibR/aprutil-1.lib $(APR_UTIL_DIR)/Release/libaprutil-1.lib
APR_LIB=$(APR_DIR)/Release/libapr-1.lib $(APR_ICONV_DIR)/Release/libapriconv-1.lib $(APR_UTIL_DIR)/Release/libaprutil-1.lib
#APACHE
APACHE_INC=-I$(APACHE_DIR)\include
APACHE_LIB=$(APACHE_DIR)\Release\libhttpd.lib
# Setup REGEX object and includes
REGEX_OBJ=$(REGEX_DIR)\regex.obj
REGEX_INC=-I$(REGEX_DIR)
# REGEX needs some special flags... here they are for VC++ 6.0
REGEX_OPT=-DHAVE_STRING_H -DREGEX_MALLOC
# Section IX: Collect compiler flags
!IFNDEF EXTERNAL_LIBS
EXTERNAL_LIBS= $(PNG_LIB) $(CURL_LIB) $(JPEG_LIB) $(APR_LIB) $(APACHE_LIB) $(FRIBIDI_LIB) $(SQLITE_LIB) $(TIFF_LIB) $(GEOTIFF_LIB) $(FCGI_LIB) $(GDAL_LIB) $(GEOS_LIB) $(BDB_LIB)
!ENDIF
LIBS=$(MAPCACHE_LIB) $(EXTERNAL_LIBS)
!IFNDEF INCLUDES
INCLUDES=$(MAPCACHE_INC) $(APR_INC) $(APACHE_INC) $(REGEX_INC) $(PNG_INC) $(ZLIB_INC) $(CURL_INC) $(JPEG_INC) $(SQLITE_INC) $(TIFF_INC) $(GEOTIFF_INC) $(FCGI_INC) $(GDAL_INC) $(GEOS_INC) $(BDB_INC)
!ENDIF
MAPCACHE_DEFS =$(REGEX_OPT) $(SQLITE_DEF) $(TIFF_DEF) $(GEOTIFF_DEF) $(FCGI_DEF) $(GDAL_DEF) $(GEOS_DEF) $(BDB_DEF)
!IFDEF WIN64
MAPCACHE_CFLAGS=$(INCLUDES) $(MAPCACHE_DEFS) -DWIN32 -D_WIN32 -DUSE_GENERIC_MS_NINT
!ELSE
!ENDIF
