[mapserver-users] Can't stop Mapserver 6.2.1 from gathering too much log into MS_ERRORFILE
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Mon Jun 3 06:23:22 PDT 2013
We have compiled Mapserver 6.2.1 for Linux and the version info is as follows
MapServer version 6.2.1
OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
SUPPORTS=GEOS INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I do not understand why this version is printing whole lot of information that I do not want into MS_ERRORFILE. I had originally no DEBUG lines in my mapfiles and now I have added DEBUG 0 on both MAP level and in each LAYER definition . Nothing helps and I keep on getting new lines into the errorfile after each GetMap. For example with a GROUP layer which is combined from 11 scale dependent layers it means 37 new lines after each request
[Mon Jun 3 16:12:25 2013].799634 loadParams() QUERY_STRING: map=/test.map&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=1059&HEIGHT=776&LAYERS=group&TRANSPARENT=TRUE&FORMAT=image%2Fpng&BBOX=-302742.3606628045,6634887.305484046,1741121.9462003412,8132563.133742593&SRS=EPSG:3067&STYLES=
[Mon Jun 3 16:12:25 2013].801140 msLoadMap(): 0.001s
[Mon Jun 3 16:12:25 2013].802506 msLayerIsVisible(): Skipping layer (mml_taustakartta_2) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802522 msLayerIsVisible(): Skipping layer (mml_taustakartta_3) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802528 msLayerIsVisible(): Skipping layer (mml_taustakartta_4) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802533 msLayerIsVisible(): Skipping layer (mml_taustakartta_5) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802537 msLayerIsVisible(): Skipping layer (mml_taustakartta_6) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802542 msLayerIsVisible(): Skipping layer (mml_taustakartta_7) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802546 msLayerIsVisible(): Skipping layer (mml_taustakartta_8) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802551 msLayerIsVisible(): Skipping layer (mml_taustakartta_9) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802555 msLayerIsVisible(): Skipping layer (mml_taustakartta_10) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802560 msLayerIsVisible(): Skipping layer (mml_taustakartta_11) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802566 msLayerIsVisible(): Skipping layer (mml_taustakartta_2) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802571 msLayerIsVisible(): Skipping layer (mml_taustakartta_3) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802575 msLayerIsVisible(): Skipping layer (mml_taustakartta_4) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802580 msLayerIsVisible(): Skipping layer (mml_taustakartta_5) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802584 msLayerIsVisible(): Skipping layer (mml_taustakartta_6) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802589 msLayerIsVisible(): Skipping layer (mml_taustakartta_7) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802593 msLayerIsVisible(): Skipping layer (mml_taustakartta_8) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802598 msLayerIsVisible(): Skipping layer (mml_taustakartta_9) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802602 msLayerIsVisible(): Skipping layer (mml_taustakartta_10) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802607 msLayerIsVisible(): Skipping layer (mml_taustakartta_11) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].802616 msDrawRasterLayerLow(mml_taustakartta_1): entering.
[Mon Jun 3 16:12:25 2013].802815 msResampleGDALToMap in effect: cellsize = 1932.163743
[Mon Jun 3 16:12:25 2013].803881 msDrawGDAL(mml_taustakartta_1): using RAW_WINDOW=76 93 1652 1501, dst=0,0,855,777
[Mon Jun 3 16:12:25 2013].803915 msDrawRasterLayerGDAL(): red,green,blue,alpha bands = 1,2,3,0
[Mon Jun 3 16:12:25 2013].847533 msDrawMap(): Layer 0 (mml_taustakartta_1), 0.045s
[Mon Jun 3 16:12:25 2013].847558 msLayerIsVisible(): Skipping layer (mml_taustakartta_2) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].847564 msLayerIsVisible(): Skipping layer (mml_taustakartta_3) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].847710 msLayerIsVisible(): Skipping layer (mml_taustakartta_4) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].847722 msLayerIsVisible(): Skipping layer (mml_taustakartta_5) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].847727 msLayerIsVisible(): Skipping layer (mml_taustakartta_6) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].847732 msLayerIsVisible(): Skipping layer (mml_taustakartta_7) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].847737 msLayerIsVisible(): Skipping layer (mml_taustakartta_8) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].847741 msLayerIsVisible(): Skipping layer (mml_taustakartta_9) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].847746 msLayerIsVisible(): Skipping layer (mml_taustakartta_10) because LAYER.MAXSCALE is too small for this MAP scale
[Mon Jun 3 16:12:25 2013].847751 msLayerIsVisible(): Skipping layer (mml_taustakartta_11) because LAYER.MAXSCALE is too small for this MAP scale
Does this have something to do with Linux and compile options or is it perhaps a bug? I have never experienced anything similar on Windows with MS4W.
-Jukka Rahkonen-
