[mapserver-users] Can't stop Mapserver 6.2.1 from gathering too much log into MS_ERRORFILE
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jun 3 06:45:58 PDT 2013
Do you have DEBUG turned on in your mapfile? Tuen this off and the
messages should go away. If they do not them someone probably left some
debug output in the code. And a bug report is needed.
-Steve
On 6/3/2013 9:23 AM, Rahkonen Jukka wrote:
> Hi,
> We have compiled Mapserver 6.2.1 for Linux and the version info is as follows
> MapServer version 6.2.1
> OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
> SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
> SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
> SUPPORTS=GEOS INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I do not understand why this version is printing whole lot of information that I do not want into MS_ERRORFILE. I had originally no DEBUG lines in my mapfiles and now I have added DEBUG 0 on both MAP level and in each LAYER definition . Nothing helps and I keep on getting new lines into the errorfile after each GetMap. For example with a GROUP layer which is combined from 11 scale dependent layers it means 37 new lines after each request
> [Mon Jun 3 16:12:25 2013].799634 loadParams() QUERY_STRING: map=/test.map&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=1059&HEIGHT=776&LAYERS=group&TRANSPARENT=TRUE&FORMAT=image%2Fpng&BBOX=-302742.3606628045,6634887.305484046,1741121.9462003412,8132563.133742593&SRS=EPSG:3067&STYLES=
> [Mon Jun 3 16:12:25 2013].801140 msLoadMap(): 0.001s
> [Mon Jun 3 16:12:25 2013].802506 msLayerIsVisible(): Skipping layer (mml_taustakartta_2) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802522 msLayerIsVisible(): Skipping layer (mml_taustakartta_3) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802528 msLayerIsVisible(): Skipping layer (mml_taustakartta_4) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802533 msLayerIsVisible(): Skipping layer (mml_taustakartta_5) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802537 msLayerIsVisible(): Skipping layer (mml_taustakartta_6) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802542 msLayerIsVisible(): Skipping layer (mml_taustakartta_7) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802546 msLayerIsVisible(): Skipping layer (mml_taustakartta_8) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802551 msLayerIsVisible(): Skipping layer (mml_taustakartta_9) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802555 msLayerIsVisible(): Skipping layer (mml_taustakartta_10) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802560 msLayerIsVisible(): Skipping layer (mml_taustakartta_11) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802566 msLayerIsVisible(): Skipping layer (mml_taustakartta_2) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802571 msLayerIsVisible(): Skipping layer (mml_taustakartta_3) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802575 msLayerIsVisible(): Skipping layer (mml_taustakartta_4) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802580 msLayerIsVisible(): Skipping layer (mml_taustakartta_5) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802584 msLayerIsVisible(): Skipping layer (mml_taustakartta_6) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802589 msLayerIsVisible(): Skipping layer (mml_taustakartta_7) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802593 msLayerIsVisible(): Skipping layer (mml_taustakartta_8) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802598 msLayerIsVisible(): Skipping layer (mml_taustakartta_9) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802602 msLayerIsVisible(): Skipping layer (mml_taustakartta_10) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802607 msLayerIsVisible(): Skipping layer (mml_taustakartta_11) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].802616 msDrawRasterLayerLow(mml_taustakartta_1): entering.
> [Mon Jun 3 16:12:25 2013].802815 msResampleGDALToMap in effect: cellsize = 1932.163743
> [Mon Jun 3 16:12:25 2013].803881 msDrawGDAL(mml_taustakartta_1): using RAW_WINDOW=76 93 1652 1501, dst=0,0,855,777
> [Mon Jun 3 16:12:25 2013].803915 msDrawRasterLayerGDAL(): red,green,blue,alpha bands = 1,2,3,0
> [Mon Jun 3 16:12:25 2013].847533 msDrawMap(): Layer 0 (mml_taustakartta_1), 0.045s
> [Mon Jun 3 16:12:25 2013].847558 msLayerIsVisible(): Skipping layer (mml_taustakartta_2) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].847564 msLayerIsVisible(): Skipping layer (mml_taustakartta_3) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].847710 msLayerIsVisible(): Skipping layer (mml_taustakartta_4) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].847722 msLayerIsVisible(): Skipping layer (mml_taustakartta_5) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].847727 msLayerIsVisible(): Skipping layer (mml_taustakartta_6) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].847732 msLayerIsVisible(): Skipping layer (mml_taustakartta_7) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].847737 msLayerIsVisible(): Skipping layer (mml_taustakartta_8) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].847741 msLayerIsVisible(): Skipping layer (mml_taustakartta_9) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].847746 msLayerIsVisible(): Skipping layer (mml_taustakartta_10) because LAYER.MAXSCALE is too small for this MAP scale
> [Mon Jun 3 16:12:25 2013].847751 msLayerIsVisible(): Skipping layer (mml_taustakartta_11) because LAYER.MAXSCALE is too small for this MAP scale
> Does this have something to do with Linux and compile options or is it perhaps a bug? I have never experienced anything similar on Windows with MS4W.
> -Jukka Rahkonen-
> mapserver-users at lists.osgeo.org
