[mapserver-users] Fwd: RFC99: Remove GD support in 7.0
Richard Greenwood
richard.greenwood at gmail.com
Fri Jun 7 13:33:28 PDT 2013
Sorry - posting back to list...
---------- Forwarded message ----------
From: Richard Greenwood <richard.greenwood at gmail.com>
Date: Fri, Jun 7, 2013 at 2:32 PM
Subject: Re: [mapserver-users] RFC99: Remove GD support in 7.0
To: thomas bonfort <thomas.bonfort at gmail.com>
On Fri, Jun 7, 2013 at 2:00 PM, thomas bonfort <thomas.bonfort at gmail.com>wrote:
> (posting back on list)
> On 7 June 2013 21:24, Richard Greenwood <richard.greenwood at gmail.com>wrote:
>> I have continued to use GIF rather than 8bit PNG because the GIF is
>> smaller. Often by as much as 15%. Is that expected? Is there anyway to get
>> PNG down to GIF size? I certainly understand the rationale for eliminating
>> GD but I am discouraged by the prospect of larger image sizes.
> I don't think that the gif vs. png format is relevant concerning file size
> when encoding the same pixel data. However, the quantity of information to
> encode in an antialiased image rendering is higher than in a non
> antialiased one, thus the higher file size when using agg/png8 vs. gd/gif.
> Even if we were to add a an agg/gif format, you would still be seeing this
> size overhead.
Yes, I think I sort of knew that but thanks for clarifying it.
> To put this bluntly, if the 15% overhead is important for you, you would
> have to stick with gd aliased rendering and the 6.4 release. I would also
> like to put this in context: a 15% overhead compared to the 2001 (2005?)
> outputs does not seem like a big deal given the evolution of available
> bandwidth since that time.
I work in some pretty rural areas where bandwidth is still limited. And
when considering bandwidth we need to keep mobile applications in mind
alos. MapServer has always been synonymous with speed and from the user
experience perspective speed is determined by the whole pipeline.
We've been supporting this technologically obsolete rendering mode for many
> years now, but imo it's time to move on.
I completely respect that. I was mainly wondering if there was a way to
reduce the anti-aliasing (and consequently the rendered image file size)
when using AGG, which I'm sure sounds like a pretty silly question given
the "A" in AGG.
Thanks for your reply and for all of the work that you do on the MapServer
project.
Rich
> regards,
> thomas
>> Rich
>> On Fri, Jun 7, 2013 at 7:27 AM, thomas bonfort <thomas.bonfort at gmail.com>wrote:
>>> Devs and Users,
>>> Please have a look at RFC99 (
>>> http://mapserver.org/development/rfc/ms-rfc-99.html). I am particularly
>>> interested in use-cases that would not be supported if GD were to be
>>> removed.
>>> cheers,
>>> Thomas
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Richard Greenwood
>> www.greenwoodmap.com
Richard Greenwood
Richard Greenwood
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130607/154eb24d/attachment.html>
