[mapserver-users] MapServer 6.2.1 and ArcSDE 10
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Tue Jun 11 08:07:21 PDT 2013
I've not done much tuning on my setup. I use SDE only when necessary and live with the performance issues. Tuning on the database itself is the best place to try and improve things. You might ping the list on this one, more folks use SDE in general than on 64-bit Linux.
Steve
From: Weisbender, Eric [mailto:Weisbend at WAPA.GOV]
Sent: Tuesday, June 11, 2013 9:55 AM
To: Lime, Steve D (MNIT); mapserver-users at lists.osgeo.org
Cc: Klein, Michael
Subject: RE: MapServer 6.2.1 and ArcSDE 10
Success! Thanks again for all your help. One last thing, do you suggest any of the other SDE Layer parameters that would improve the speed/performance.
Thanks,
Eric Weisbender
Western Area Power Administration
Corporate Service Office
U.S. Dept. of Energy
office: (720) 962-7280
email: weisbend at wapa.gov<mailto:weisbend at wapa.gov>
From: Lime, Steve D (MNIT) [mailto:Steve.Lime at state.mn.us]
Sent: June 10, 2013 3:01 PM
To: Weisbender, Eric
Cc: Klein, Michael
Patch goes into your source directory and I believe you just do something like:
patch <4531.diff
Or you can just edit mapsde.c by hand based on the patch- it's straight forward. Then just recompile.
Steve
Sent: Monday, June 10, 2013 3:58 PM
Cc: Klein, Michael
I just now realized that. Where do I put the patch and how do I compile against it?
Thanks,
Eric Weisbender
Sent: June 10, 2013 2:00 PM
Looks like you still have a 64/32-bit type error. Did you apply the patch I supplied last week?
Sent: Monday, June 10, 2013 2:53 PM
To: Lime, Steve D (MNIT); mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Hello,
I recompiled MapServer / SDE setting CFLAGS='-DSDE64'. I am now getting the following error when I try to draw the SDE Layer.
msDrawMap(): Image handling error. Failed to draw layer named 'sde' sdeCopyShape(): SDE error. Unsupported SDE shape type (140733193388036).
This is my SDE Layer Definition. Any help would be greatly appreciated.
LAYER
NAME "sde"
TYPE LINE
STATUS OFF
CONNECTION "JLVGISGATEM,5353,sde,cso_editor,c1rcu1t#"
CONNECTIONTYPE SDE
DATA "RMR.MNT_SPANS,SHAPE,SDE.DEFAULT"
TEMPLATE "/data/gis/www/html/ms_common/tlines.html"
CLASS
STYLE
COLOR 200 200 0
WIDTH 10
END
END
END
Thanks,
Eric Weisbender
Sent: June 07, 2013 1:46 PM
To: Weisbender, Eric; mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Ah, I ran into this to as well, see ticket https://github.com/mapserver/mapserver/issues/4521. I've attached a diff that made things work well for me. Once a fix is put in place for 6.4 (git master) we can backport to 6.2.
Steve
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Weisbender, Eric
Sent: Friday, June 07, 2013 2:26 PM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] MapServer 6.2.1 and ArcSDE 10
Hello,
We have successfully compiled MapServer 6.2.1 with ArcSDE10 and can see the SDE server ok. When I try to draw a line layer I get the following error.
msDrawMap(): Image handling error. Failed to draw layer named 'sde' msSDELayerWhichShapes(): SDE error. getSDEQueryInfo(): Success. (0 getSDEQueryInfo(): SDE error. SE_queryinfo_set_columns(): Invalid parameter value passed to function. (4294967230)
The layer definition looks like this and all of the parameters look good.
LAYER
NAME "sde"
TYPE LINE
STATUS OFF
CONNECTIONTYPE SDE
CLASS
STYLE
COLOR 200 200 0
WIDTH 10
END
END
END
If anyone has an idea of what I am missing or doing wrong any help is greatly appreciated.
Thanks,
Eric Weisbender
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130611/8437e829/attachment-0001.html>
