[mapserver-users] Misusing default TIME values in WMS?
John D. Evans
john.evans at gst.com
Tue Jun 11 09:43:19 PDT 2013
Hi all,
My MapServer WMS service seems to be misusing the default times I have
defined on map layers. It (correctly) uses the default time for GetMap
requests that specify no time at all; however it (incorrectly) uses this
time also for requests that specify a time outside the layer's available
times. (For, say, time=2017-09-21, it returns today's image... which is
very confusing.)
The WMS Capabilities doc shows <Extent name="time" ... nearestValue="0">
which is what I want -- but it doesn't match the above behavior. Excerpt:
<Layer queryable="0" opaque="0" cascaded="0">
<Name>iicmocp_time_idx</Name>
<Title>Time Index for iicmocp</Title>
<SRS>EPSG:4326</SRS>
</Layer>
<Name>iicmocp_daily</Name>
<Title>csppnppviirssdr iicmocp daily</Title>
<Abstract>Some important description here...</Abstract>
<Dimension name="time" units="ISO8601"/>
<Extent name="time" default="2013-06-11"
nearestValue="0">2013-06-09/2013-06-11T09:16/P1D</Extent>
</Layer>
Is this a bug in mapserv? Or have I just misconfigured my time index?
(Mapfile excerpts below.)
Thanks.
- John Evans
p.s. My mapfile has the following details for these layers:
LAYER
NAME "iicmocp_daily"
TYPE RASTER
STATUS off
OFFSITE 0 0 0
TRANSPARENCY 80
TILEINDEX "iicmocp_time_idx"
TILEITEM "tiffpath"
METADATA
"wms_srs" "EPSG:4326"
"wms_title" "csppnppviirssdr iicmocp daily"
"wms_layer_group" "/csppnppviirssdr iicmocp imagery"
"wms_abstract" "Some important description here..."
"wms_timeextent" "2013-06-09/2013-06-11T09:16/P1D"
"wms_timedefault" "2013-06-11"
"wms_timeitem" "filedate"
"wms_timeformat" "YYYY-MM-DD,YYYY-MM-DDTHH,YYYY-MM-DDTHH:MM"
END
END
LAYER
NAME "iicmocp_time_idx"
TYPE POLYGON
DATA "geom from iicmocp"
METADATA
"wms_title" "Time Index for iicmocp"
END
CONNECTIONTYPE POSTGIS
CONNECTION "host=localhost port=5432 dbname=mapdemo ..."
END
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130611/304f03a5/attachment.html>
