[mapserver-users] RE WMS layer filtering (UNCLASSIFIED)
Smith, Michael ERDC-CRREL-NH
Michael.Smith at usace.army.mil
Wed Jun 12 05:57:17 PDT 2013
Classification: UNCLASSIFIED
Caveats: NONE
Could you use script wrappers to set different environment variables
Eg a wms file and a wfs file
Your WMS file
#!/bin/sh
MS_MAPFILE=/path/to/mapfile
export MS_MAPFILE
export LATEST_OBS=1
/cgi-bin/mapserv
WFS File
#!/bin/sh
export MS_MAPFILE
export LATEST_OBS=0
/cgi-bin/mapserv
And then use %LATEST_OBS% in your
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Kralidis,Tom [Ontario]
Sent: Wednesday, June 12, 2013 8:44 AM
To: Steve.Toutant at inspq.qc.ca
Cc: mapserver-users at lists.osgeo.org; mapserver-users-bounces at lists.osgeo.org
Subject: Re: [mapserver-users] RE WMS layer filtering
Steve: thanks for the info. Good point. It would help, however the client would require apriori knowledge, which won't help in our case because we want things more generic.
Of course, there's always MapScript (i.e. set LAYER.FILTER only if it's a WMS GetMap/GetFeatureInfo request), but I was hoping for something less involved, or configurable.
From: Steve.Toutant at inspq.qc.ca [mailto:Steve.Toutant at inspq.qc.ca]
Sent: June 12, 2013 8:40 AM
To: Kralidis,Tom [Ontario]
Subject: RE [mapserver-users] WMS layer filtering
Does runtime substitution can help?
You could post latest_observation=1 when calling the wms and 0 and 1 when using the wfs
the filter would be latest_observation in (%param%)
"Kralidis,Tom [Ontario]" <Tom.Kralidis at ec.gc.ca>@lists.osgeo.org
Envoyé par : mapserver-users-bounces at lists.osgeo.org
2013-06-12 08:23
A
<mapserver-users at lists.osgeo.org>
cc
Objet
Hi: we have a MapServer OWS instance which we use to disseminate
observations via WMS and WFS/SOS.
One of our layers has 1 million records (PostGIS backend). The layer
has CLASS level EXPRESSION objects for WMS visualization/classification.
We initially implemented a LAYER level FILTER, however we have use cases
to serve the same layer (with the same identifier) via WFS, in which
case we'd like all the data to be available.
Our problem happens when visualizing via WMS. We have a Boolean column
in our PostGIS table ('latest_observation') which allows us to filter
easily to visualize latest observations, which is our desired WMS
default.
Because we have defined CLASS level filters, the WMS GetMap request is
first querying and fetching all records and _then_ applying CLASS level
filters (which all include 'latest_observation=1'. So this ends up
hurting us performance wise.
We'd like to have this filter at the query level so that less members
are passed back from the SQL query.
When we do a LAYER.FILTER with latest_observation=1, the result is
instant (beautiful!). But if we put a LAYER.FILTER, this constrains the
data access from the WFS perspective against the same LAYER def.
Is there any way to apply a LAYER.FILTER type approach to work _just_ in
WMS mode? We'd like all the data in WFS mode.
I know we can duplicate the LAYER object as a workaround, but from a
data management perspective we'd rather now.
I hope I have explained this clearly enough. Any suggestions?
Thanks
..Tom
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Caveats: NONE
