[mapserver-users] Issue with correct distance/length displaying on scalebar in Mapfile
David Pardy
david.pardy at airborne.aero
Wed Jun 19 15:13:11 PDT 2013
Prior to the scalebar, I had set the projection the same per layer:
PROJECTION
"proj=longlat"
"ellps=WGS84"
"datum=WGS84"
END
After getting the scalebar to appear, I notice the lengths/distances
were not correct, so I decided to add a map projection outside all the
layers. Same as above.
My scalebar is as follows:
SCALEBAR
LABEL
COLOR 0 0 0
SIZE SMALL
END
STYLE 0
SIZE 180 8
POSITION lc
COLOR 0 0 0
UNITS MILES
INTERVALS 2
TRANSPARENT TRUE
STATUS EMBED
END
Any help on the matter would be greatly appreciated.
Thank you.
David
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130619/d4434eae/attachment.html>
