[mapserver-users] Spatialite and spatial index?
Sven Geggus
lists at fuchsschwanzdomain.de
Tue Jun 25 01:57:51 PDT 2013
Rahkonen Jukka <jukka.rahkonen at mmmtike.fi> wrote:
> I encourage you to have a try with GDAL 1.10 because I believe that
> for your use case Spatialite will be considerable faster than
> PostGIS.
Thanks! It seems to work fine using gdal 1.10 now and seems to be
slightly faster that using postgis.
> If you can tolerate Windows the builds from
> http://gisinternals.com/sdk/ should work well.
I'm not using windows, but I managed to package custom Debian
packages of gdal 1.10 :)
Sven
Der "normale Bürger" ist nicht an der TU Dresden und schreibt auch
nicht mit mutt. (Ulli Kuhnle in de.comp.os.unix.discussion)
/me is giggls at ircnet, http://sven.gegg.us/ on the Web
