[mapserver-users] mapcache - multiple resolutions for the same grid
thomas bonfort
thomas.bonfort at gmail.com
Mon Mar 4 08:19:23 PST 2013
<tileset>
<grid minzoom="0" maxzoom="19">...</grid>
</tileset>
should do the trick...
On 4 March 2013 17:14, Travis Kirstine <traviskirstine at gmail.com> wrote:
> I have set up mapcache with a generic grid for all my caches. The grid has
> resolutions defined for zoom levels 0-21, however depending on the
> resolution of my source data the tileset may only be seeded to level 19.
> The tileset no longer has the ability to connect to the source. As a result
> blank images are displayed the when a client using the mapcache WMS zooms in
> beyond the max resolution. Is there a way to address this without creating
> additional grids?
> <!-- Google Grid for >=10cm Levels 0-21 -->
> <grid name="gmaps">
> <metadata>
> <title>GoogleMapsCompatible</title>
> <WellKnownScaleSet>urn:ogc:def:wkss:OGC:1.0:GoogleMapsCompatible</WellKnownScaleSet>
> </metadata>
> <extent>-20037508.3427892480 -20037508.3427892480 20037508.3427892480
> 20037508.3427892480</extent>
> <srs>EPSG:3857</srs>
> <srsalias>EPSG:900913</srsalias>
> <units>m</units>
> <size>256 256</size>
> <resolutions>156543.0339280410 78271.51696402048 39135.75848201023
> 19567.87924100512 9783.939620502561 4891.969810251280 2445.984905125640
> 1222.992452562820 611.4962262814100 305.7481131407048 152.8740565703525
> 76.43702828517624 38.21851414258813 19.10925707129406 9.554628535647032
> 4.777314267823516 2.388657133911758 1.194328566955879 0.5971642834779395
> 0.29858214173896975 0.149291070869484875 0.0746455354347424375</resolutions>
> </grid>
> <tileset name="0237DURH_cache">
> <!--source>0237DURH</source-->
> <cache>disk</cache>
> <grid restricted_extent="-8831574.381510 5432633.752429 -8731299.465116
> 5547099.028228">gmaps</grid>
> <format>mixed</format>
> <metatile>4 4</metatile>
> <metabuffer>0</metabuffer>
> </tileset>
> Thanks!
> mapserver-users at lists.osgeo.org
