[mapserver-users] How use style for distinguish the rendering for scales interval.
thomas bonfort
thomas.bonfort at gmail.com
Thu Mar 7 01:09:23 PST 2013
The legend renderer does not honor style minscale/maxscale. You might
want to open an issue about that.
thomas
On 7 March 2013 10:04, Andrea Peri <aperi2007 at gmail.com> wrote:
> Here is an example of what it is returning.
> (see attached image)
> As you can see every element has a color fill and a black boundaries.
> Instead the rendering in the map is for a class
> with a double style.
> in an interval of scale act a style with a coloured solid fill and a
> white boundaries, and in another scale interval act another style with
> a black boundary and no fill inside.
> The getlegendgraphics result is the merge of both.
> 2013/3/5 Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>:
>> I dunno, I'm thinking the problem may lay in the legend code not respecting scale values. What exactly does your GetLegendGraphic call look like?
>> Steve
>> ________________________________________
>> From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] on behalf of Carlo Pelliconi [c.pelliconi at sis-ter.it]
>> Sent: Tuesday, March 05, 2013 6:27 AM
>> To: aperi2007 at gmail.com
>> Cc: mapserver-users at lists.osgeo.org
>> Subject: Re: [mapserver-users] How use style for distinguish the rendering for scales interval.
>> Hi Andrea,
>> If I remember well, the legend represents the class objects, so my
>> advice is to create 2 different classes, with 1 style each one. Use the
>> maxscaledenom statement in the class definition and not in the style.
>> I hope it works.
>> Bye, Carlo
>> Il 04/03/2013 14:59, Andrea Peri ha scritto:
>>> Hi,
>>> I have set a layer with a class and 2 style inside the class.
>>> The first style is working in a specific sclae interval, the second
>>> style is in another different scale interval.
>>> To do this I use this code:
>>> MAP
>>> CLASS
>>> MAXSCALEDENOM 4000000
>>> MINSCALEDENOM 1
>>> # the style A
>>> STYLE
>>> WIDTH 2.0
>>> COLOR "#C5C9977F"
>>> ANTIALIAS false
>>> OPACITY 100
>>> MINSCALEDENOM 100000
>>> # the style B
>>> STYLE
>>> WIDTH 3.0
>>> OUTLINECOLOR "#000000FF"
>>> ANTIALIAS false
>>> OPACITY 100
>>> MAXSCALEDENOM 100000
>>> MINSCALEDENOM 1
>>> So in the scale interval 1:100.000 - 1:4.000.000 the geometry is with
>>> a color fill and an outline
>>> instead in the scale interval 1:1 - 1:100.00 the geometry is with only
>>> an outline with width 3.
>>> But when I call the GetçLegendGraphics using a scale of 1:300.000
>>> Instead of a legend with the styleA only I have a legend-image with
>>> styleA+styleB
>>> I'm using the mapserver 6.3dev.
>>> I guess there is some mistake on the styles definition but I don't find what.
>>> Any hint is welcome.
>>> thx,
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Andrea Peri
> qwerty àèìòù
