[mapserver-users] Access network share drive for data in mapfile throwing error
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Mar 7 08:03:32 PST 2013
I might be wrong, but I do not believe you can access files using the
this windows syntax. You have to use a mapped drive. Also you should
flip all you path separator characters from \ to / as \ is an escape
character in a lot of contexts.
So try something like:
d:/data/SheridanData/Keeneland/Vector Data/Geographic
Control Points/Geographic Control Points.shp
-Steve W
On 3/7/2013 10:48 AM, Sowmya Tiramdasu wrote:
> Hi,
> I am trying to access data directly from a network share folder in my
> mapfile. But it is not working . It is throwing the following error.
> msDrawMap(): Image handling error. Failed to draw layer named
> 'ControlPoints'.
> msShapefileOpen(): Unable to access file.
> (\DISKSTATION1\data\SheridanData\Keeneland\Vector Data\Geographic
> Control Points\Geographic Control Points.shp)
> msSHPLayerGetItems(): Shapefile error. Shapefile layer has not been opened.
> KmlRenderer::startNewLayer: General error message. msLayerOpen failed
> I tried to search in the old email archives. In one of the email chains
> they suggested me to check if gdal/ogr can actually open the files. I
> did gdal info for tiff files and they are giving the right information.
> Similarly ogrinfo for shp files and they too are fine.
> Can anyone please suggest what is the problem and give me solution to
> fix this. Find below snapshot of my mapfile for your reference.
> LAYER
> NAME KeenelandStatePlane38
> DATA
> "\\DISKSTATION1\data\SheridanData\Keeneland\Imagery\StatePlane\SPSPSPO-00039.tif"
> STATUS OFF
> TYPE RASTER
> OPACITY 75
> PROJECTION
> "init=EPSG:102679"
> END
> DEBUG 5
> END
> LAYER
> NAME ControlPoints
> #Photogrammetric points
> DATA
> "\\DISKSTATION1\data\SheridanData\Keeneland\Vector Data\Geographic
> Control Points\Geographic Control Points.shp"
> STATUS OFF
> TYPE POINT
> CLASS
> STYLE
> Symbol to be used (reference)
> SYMBOL
> "circle"
> # Size
> of the symbol in pixels
> SIZE 8
> COLOR
> 190 20 190
> Outline colour (RGB) - black
> OUTLINECOLOR 0 0 0
> END
> END
> PROJECTION
> "init=epsg:102679"
> END
> END
> Thanks in advance,
> Sowmya.
> mapserver-users at lists.osgeo.org
