[mapserver-users] Access network share drive for data in mapfile throwing error
Sowmya Tiramdasu
stiramdasu at lp360.com
Thu Mar 7 09:51:02 PST 2013
Hi Andy,
Thanks for your suggestion. Giving an extra slash worked :)
Stephen : I think the windows path doesn't give any problem. So the slashes
are not the issue here. Anyways thanks for your suggestion.
Thanks,
Sowmya.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Andy Colson
Sent: Thursday, March 07, 2013 10:00 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Access network share drive for data in
On 3/7/2013 9:48 AM, Sowmya Tiramdasu wrote:
> Hi,
> I am trying to access data directly from a network share folder in my
> mapfile. But it is not working . It is throwing the following error.
> msDrawMap(): Image handling error. Failed to draw layer named
> 'ControlPoints'.
> msShapefileOpen(): Unable to access file.
> (\DISKSTATION1\data\SheridanData\Keeneland\Vector Data\Geographic
> Control Points\Geographic Control Points.shp)
> msSHPLayerGetItems(): Shapefile error. Shapefile layer has not been
opened.
> KmlRenderer::startNewLayer: General error message. msLayerOpen failed
> I tried to search in the old email archives. In one of the email chains
> they suggested me to check if gdal/ogr can actually open the files. I
> did gdal info for tiff files and they are giving the right information.
> Similarly ogrinfo for shp files and they too are fine.
> Can anyone please suggest what is the problem and give me solution to
> fix this. Find below snapshot of my mapfile for your reference.
> LAYER
> NAME KeenelandStatePlane38
> DATA
"\\DISKSTATION1\data\SheridanData\Keeneland\Imagery\StatePlane\SPSPSPO-00039
.tif"
> STATUS OFF
> TYPE RASTER
> OPACITY 75
> PROJECTION
> "init=EPSG:102679"
> END
> DEBUG 5
> END
> LAYER
> NAME ControlPoints
> #Photogrammetric points
> DATA
> "\\DISKSTATION1\data\SheridanData\Keeneland\Vector Data\Geographic
> Control Points\Geographic Control Points.shp"
> STATUS OFF
> TYPE POINT
> CLASS
> STYLE
> Symbol to be used (reference)
> SYMBOL
> "circle"
> # Size
> of the symbol in pixels
> SIZE 8
> COLOR
> 190 20 190
> Outline colour (RGB) - black
> OUTLINECOLOR 0 0 0
> END
> END
> PROJECTION
> "init=epsg:102679"
> END
> END
> Thanks in advance,
> Sowmya.
The error: Unable to access file. (\DISKSTATION1\..
Is missing a slash on front. Maybe in your mapfile, try three slashes
up front:
>DATA "\\\DISKSTATION1\data...
-Andy
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
