[mapserver-users] Mapfile with different CRS
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Sun Mar 10 14:03:52 PDT 2013
Server URL for GetCapabilities is http://geoposer.com:443/server/services/osm.xml?service=WMS=version=1.1.1&request=GetCapabilities
If you check the response you will see that the GetMap URL is
http://data1.geoposer.com:443/server/services/request.php?jname=/wms.img
Use that as your CONNECTION and you should be OK.
I see that you create your mapfiles with QGis Mapfile export plugin. It does not create totally valid mapfiles but this layer works for me.
-Jukka Rahkonen-
ALT SHN wrote:
> Hello users,
> I have a this mapfile wich under the "MAP" section has epsg:3763 has the general CRS.
> I'm trying to add a WMS server containing OSM data. This WMS delivers the data in WGS84. So, under >"Layers" section I added this:
LAYER
NAME 'Open Street Map'
TYPE RASTER
DUMP true
TEMPLATE fooOnlyForWMSGetFeatureInfo
EXTENT -9.827190 38.978798 -8.728572 39.676104
CONNECTIONTYPE WMS
CONNECTION 'http://geoposer.com:443/server/services/osm.xml'
METADATA
'ows_name' 'osm'
'wms_server_version' '1.1.1'
'ows_srs' 'EPSG:4326'
'wms_format' 'image/jpeg'
'wms_style' ''
END
METADATA
'ows_title' 'osm'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
"init=epsg:4326"
END
END
However, the layer simply does not shows. I'm kinda lost here. Any Idea Why this might be happening?
Thank you,
Associação Leonel Trindade
SOCIEDADE DE HISTÓRIA NATURAL
Apartado 25 2564-909 Torres Vedras Portugal
Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto do Ameal 2565-641 Ramalhal
http://alt-shn.blogspot.com
www.alt-shn.org<http://www.alt-shn.org>
More information about the MapServer-users
