[mapserver-users] Mapcache FCGI with IIS...
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Mar 12 10:16:53 PDT 2013
Paul,
I have always use the apache module, so this might be useless info. I
guessing that you would configure it under IIS like any other FCGI
module. The trick is that you need to inform it where its mapcache.xml
config file is located. In apache that is passed as an envronment
variable. Then you should be able to hit the configured url for the service.
http://sever/mapcache.exe/demo
http://sever/mapcache.exe?demo
And it should respond with the demo service page if that is configured
in the mapcache.xml.
This might give you some ideas:
http://lists.osgeo.org/pipermail/mapserver-dev/2012-February/012007.html
-Steve W
On 3/12/2013 12:38 PM, Paul james wrote:
> Thanks...
> I compiled mapcache with success ... mapcache_seed is working fine...
> But I dont know how use the FastCGI module (mapcache.exe) ... I created
> a FastCGI 'Module Mapping' in IIS pointing to mapcache.exe ... But how
> can I use that in my atual map? I didnt find any tutorial/guide how use
> Mapcache as FastCGI independent module...
> Paul
> On Mon, Mar 11, 2013 at 3:05 PM, Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> wrote:
> On 2013-03-11 2:42 PM, Paul james wrote:
> > Thanks Jeff...
> > I updated my mapache (master) and now I only got 1 unresolved
> symbol :
> > */Creating library cgi\mapcache.lib and object cgi\mapcache.exp
> > mapcache.obj : error LNK2019: unresolved external symbol
> > __imp__apr_date_parse_http4 referenced in function
> _fcgi_write_response
> > cgi\mapcache.exe : fatal error LNK1120: 1 unresolved externals
> > NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual
> > Studio 11.0\VC\BIN\cl.EXE"' : return code '0x2'
> > Stop./*
> > Do you have any idea how can I fix that?
> > Thanks
> Since that function comes from the APR library (apr-util i think), maybe
> make sure you set all the APR declarations in your nmake.opt
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
