[mapserver-users] postgis layers don't show up
Pedro Costa
pedrocostaarma at sapo.pt
Thu Mar 14 02:56:26 PDT 2013
Very strange...I got nothing again:
select st_astext(st_extent(the_geom)) from ruas:
RESULT:
"POLYGON((88386.2413216648 122184.527972102,88386.2413216648
124022.075913784,91216.2575858403 124022.075913784,91216.2575858403
122184.527972102,88386.2413216648 122184.527972102))"
select count(*)
from ruas
where the_geom && GeomFromText
('POLYGON((88386.2413216648 122184.527972102,88386.2413216648
122184.527972102,88386.2413216648 122184.527972102))',27492);
RESULT: 0
Em 13-03-2013 18:27, Stephen Woodbridge escreveu:
> On 3/13/2013 1:49 PM, Pedro Costa wrote:
>> Em 13-03-2013 17:39, Stephen Woodbridge escreveu:
>>> So What do you get in pgadmin or psql with:
>>> select count(*)
>>> from ruas
>>> where the_geom && GeomFromText('POLYGON((88071.2044330519
>>> 122184.53,88071.2044330519 124022.08,91531.2955669481
>>> 124022.08,91531.2955669481 122184.53,88071.2044330519
>>> 122184.53))',27492);
>> nothing...count = 0...
> This means there is some kind of disconnect between the data in the
> database and how you have it defined in the mapfile.
>>> select st_astext(st_extents(st_collect(the_geom))) from ruas;
>> Previously i have compared the result of 'st_extent' with extent in
>> mapfile and its the same....
>> Your query with st_collects give me an error (ERROR: aggregate function
>> calls cannot be nested)....
> Try:
> select st_astext(st_extents(the_geom)) from ruas;
> Once you get this you will have the min and max extents of the data in
> the database and you can compare that to the polygon above and see if
> it overlaps.
> -Steve
>>> -Steve
>>> On 3/13/2013 1:22 PM, Pedro Costa wrote:
>>>> Yes, i confirmed that right now, its the bb but i don't understand the
>>>> problem because in other server (with the same coordinates) this works
>>>> fine.
>>>> i'm also confirmed the extent in qgis and its correct...
>>>> my mapfile top data:
>>>> EXTENT 88386.2 122329.41 91216.3 124022.08
>>>> UNITS meters
>>>> SIZE 500 500
>>>> SHAPEPATH "shape"
>>>> SYMBOLSET "../common/symbols/symbols-pmapper.sym"
>>>> FONTSET "../common/fonts/msfontset.txt"
>>>> RESOLUTION 96
>>>> IMAGETYPE png
>>>> INTERLACE OFF
>>>> PROJECTION
>>>> "init=epsg:27493"
>>>> END
>>>> my layer:
>>>> LAYER
>>>> NAME "ruas"
>>>> STATUS DEFAULT
>>>> DEBUG 5
>>>> TYPE LINE
>>>> CONNECTIONTYPE postgis
>>>> PROCESSING "CLOSE_CONNECTION=DEFERl"
>>>> CONNECTION "user=pedro password=****** dbname=norte
>>>> host=localhost
>>>> options='-c client_encoding=LATIN1'"
>>>> DATA "the_geom from ruas using unique n_rua using srid=27493"
>>>> TOLERANCE 3
>>>> TOLERANCEUNITS pixels
>>>> TEMPLATE void
>>>> PROJECTION
>>>> "init=epsg:27493"
>>>> END
>>>> METADATA
>>>> "DESCRIPTION" "Ruas"
>>>> "RESULT_FIELDS" "id"
>>>> "RESULT_HEADERS" "id"
>>>> "ows_title" "Ruas "
>>>> END # Metadata
>>>> CLASS
>>>> Name 'ruas'
>>>> COLOR 0 0 0
>>>> END # Class
>>>> END
>>>> Em 13-03-2013 17:14, Stephen Woodbridge escreveu:
>>>>> The polygon is the bounding box of the image that you requested.
>>>>> Mapserver only needs the geometries the cross of the map image and
>>>>> this is what the where clause is doing.
>>>>> Why do you thin this is not correct? What does the top of you mapfile
>>>>> look like and what does this LAYER definition look like?
>>>>> -Steve W
>>>>> On 3/13/2013 1:12 PM, Pedro Costa wrote:
>>>>>> Thanks to all.
>>>>>> The problem is the query.despite don't give me any error returns 0
>>>>>> features...
>>>>>> This happens because the 'where with the polygon' [1]...
>>>>>> Anybody knows the origin of that polygon?
>>>>>> select encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR'),'hex') as
>>>>>> geom,"n_rua"
>>>>>> from ruas
>>>>>> 122184.53))',27492)
>>>>>> Em 13-03-2013 16:54, Carlo Pelliconi escreveu:
>>>>>>> I think like others that the problem could be in srid definition.
>>>>>>> Remember that you need to define an srid for the mapfile and an
>>>>>>> srid
>>>>>>> for each layer in the mapfile.
>>>>>>> When using postgis connectiontype I also put "using
>>>>>>> srid=yourPostGisLayerSrid" in the DATA sql statement of the layer
>>>>>>> (mandatory? I don't know, but it works)
>>>>>>> Hope this helps.
>>>>>>> Best Regards, Carlo
>>>>>>> Il 13/03/2013 12:40, Pedro Costa ha scritto:
>>>>>>>> Hi guys,
>>>>>>>> I have one mapfile with conections to postgis layers and one
>>>>>>>> raster.
>>>>>>>> My problem is that the layers from postgis don't show up...If i
>>>>>>>> make
>>>>>>>> the request without the raster i got only white images...
>>>>>>>> I have the debug level in 5 and I got no erros in all logs
>>>>>>>> (including
>>>>>>>> apache)...
>>>>>>>> The permissions of the database are correct because I tried
>>>>>>>> accessing
>>>>>>>> with qgis and it worked fine. I'm also try specified the
>>>>>>>> projection
>>>>>>>> ("using srid = 27493") but without sucess...
>>>>>>>> I'm also tried add one of the Iayers of db but from a shape and
>>>>>>>> worked fine...
>>>>>>>> Furthermore, very strange is that when I try to run mapfile with
>>>>>>>> pmapper, I can search for attributes and zoom to the correct areas
>>>>>>>> (despite can't see geometries) ...
>>>>>>>> Anybody have an idea?
>>>>>>>> Thanks
>>>>>>>> SO: Ubuntu server
>>>>>>>> MapServer version 6.0.1
>>>>>>>> _______________________________________________
>>>>>>>> mapserver-users mailing list
>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
