[mapserver-users] lcc projection doesnt output map
Mark Mirrlees
mmirrlees at hotmail.com
Sun Mar 17 17:58:36 PDT 2013
I dont have linux, im using windows based mapserver...plus I can't figure out how to work the conversion. So i'm not sure what the numbers should be.... and do I have to change anything in what I have bolded? PROJECTION
"proj=lcc"
"ellps=GRS80"
"lat_0=-143"
"lon_0=-39"
"lat_1=-50"
"lat_2=85"
"datum=NAD83"
"units=m"
"no_defs"
> Date: Sun, 17 Mar 2013 20:39:50 -0400
> From: woodbri at swoodbridge.com
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] lcc projection doesnt output map
> Mark,
> You need to change
> UNITS DD
> to
> UNITS METERS
> and you need to change
> EXTENT -143 39 -50 85
> to
> EXTENT ...
> where ... is the longlat coordinates above converted to their equivalent
> values in LCC
> On linux you might from cs2cs command helpful, you might also find some
> online projection conversion utilities.
> -Steve
> On 3/17/2013 8:26 PM, Mark Mirrlees wrote:
> > Hi all,
> > when I try to edit my projection to a LCC from a UTM in my mapfile my
> > map fails to show up when I launch my mapserver link.
> > Here is the first part of the mapfile...
> > BEFORE:
> > MAP
> > NAME "QGIS-MAP"
> > # Map image size
> > SIZE 500 500
> > UNITS meters
> > FONTSET "/wwwroot/fonts/fontset.txt"
> > SYMBOLSET "/wwwroot/symbols/symbols.sty"
> > PROJECTION
> > 'proj=longlat'
> > 'datum=WGS84'
> > 'no_defs'
> > END
> > AFTER:
> > MAP
> > NAME "QGIS-MAP"
> > # Map image size
> > SIZE 500 500
> > UNITS dd
> > PROJECTION
> > "proj=lcc"
> > "ellps=GRS80"
> > "lat_0=49"
> > "lon_0=-95"
> > "lat_1=49"
> > "lat_2=77"
> > "datum=NAD83"
> > "units=m"
> > "no_defs"
> > END
> > I'm not sure how to fix this...any suggestions? As i'm still fairly new
> > at this.
> > Mark
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130317/31672f01/attachment.html>
