[mapserver-users] label issues...
Mark Mirrlees
mmirrlees at hotmail.com
Mon Mar 18 13:20:48 PDT 2013
Ok so if I understand this is what it should look like? (stuff thats been added is in red) Please correct this if i'm wrong as I am still having a bit of problems... LAYER
NAME 'mjcities'
TYPE POINT
DUMP false
EXTENT -143.210462 39.001401 -50.461045 85.911094
DATA '../data/mjcities.shp'
METADATA
'ows_title' 'mjcities'
END
STATUS default
MAXSCALE 1000000
TRANSPARENCY 100CLASSLABEL COLOR 255 255 255
FONT "arial"
TYPE "truetype"
SIZE 10
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS falseENDPROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'mjcities'
STYLE
SYMBOL "circle"
SIZE 15.0
OUTLINECOLOR 0 0 0
COLOR 182 109 194
END
To: mmirrlees at hotmail.com; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] label issues...
Date: Mon, 18 Mar 2013 20:05:55 +0000
You want to create a class in your layer and place it there.
http://mapserver.org/mapfile/class.html
Like this:
MAP
LAYER
CLASS
LABEL
END # end of label
END # end of class
END #end of layer
END #end of map
From: Mark Mirrlees [mailto:mmirrlees at hotmail.com]
Sent: Monday, March 18, 2013 3:00 PM
To: Fawcett, David (MNIT); mapserver-users at lists.osgeo.org
Ok so I want to stick this code into the .map file... where should it be placed in the section that i bolded?
LABEL
COLOR 255 255 255
FONT "arial"
TYPE "truetype"
SIZE 10
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
Thanks,
Mark
David.Fawcett at state.mn.us
Date: Mon, 18 Mar 2013 19:51:42 +0000
Mark,
You will want to add a LABEL block to your mapfile.
http://mapserver.org/mapfile/label.html
I would also comment out the maxscale until you get the labels working.
David.
mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org]
On Behalf Of Mark Mirrlees
Sent: Monday, March 18, 2013 2:48 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] label issues...
Hi all,
Ok so now I have a new problem with the labeling.
I would like to get my labels to start showing up at a scale of 1:1000000 but nothing is working...
here is a snippet of my mapfile...
LAYER
NAME 'mjcities'
TYPE POINT
DUMP false
METADATA
END
STATUS default
MAXSCALE 1000000
TRANSPARENCY 100
CLASSITEM 'NAME'
LABELITEM 'NAME'
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'mjcities'
STYLE
SYMBOL "circle"
SIZE 15.0
OUTLINECOLOR 0 0 0
COLOR 182 109 194
END
Thanks,
Mark
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130318/7f16fbf2/attachment-0001.html>
