[mapserver-users] query creation issues
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Mar 20 11:45:44 PDT 2013
On 3/20/2013 2:32 PM, Mark Mirrlees wrote:
> Hi Steve,
> Unfortunately that didn't work! But I did manage to get the ID
> chracteristic outputted as I forgot to include that previously.
> As when I went to edit the query.html page it shows this
> ID Name Type
> 1275
> [name]
> [type]
> Here is the code that is causing issues for me...
> <!-- MapServer Template -->
> <!--<IMG
> src="http://[host]/cgi-bin/mapserv.exe?mode=INDEXQUERY&qformat=png24&qlayer=mjrroads&shapeindex=[shpidx]&shpext=[shpext_esc]&mapext=shape&map=[map]">-->
> <tr>
> <td>[shpidx]</td>
> <tr><td>[name]</td></tr>
> <tr><td>[type]</td></tr>
> </tr>
Attribute binding is case sensitive. For shapefiles it should be
UPPERCASE and for postgis it should be lowercase.
Also, you tags are not nested correctly, you have a tr nested inside a
tr. :-O
-Steve W
> While this is the code for the header...
> <h3><b>Layer: Major Roads</b></h3>
> <br>
> <INPUT NAME="img" TYPE="image" SRC="[img]" width=500 height=500 border=0
> ALT="Map Image">
> <table border=1>
> <tr> </td>
> <th>ID</th>
> <th>Name</th>
> <th>Type</th>
> </tr>
> As what i'm trying to do is get the name (name of road outputted) and
> the type (either expressway or major road)
> Thanks,
> Mark
> From: Steve.Lime at state.mn.us
> To: mmirrlees at hotmail.com; mapserver-users at lists.osgeo.org
> Subject: RE: [mapserver-users] query creation issues
> Date: Wed, 20 Mar 2013 18:22:29 +0000
> You need to refer to the attributes next…
> <tr><td>[NAME]</td><td>[TYPE]</td></tr>
> Steve
> *From:*Mark Mirrlees [mailto:mmirrlees at hotmail.com]
> *Sent:* Wednesday, March 20, 2013 12:16 PM
> *To:* Lime, Steve D (MNIT); mapserver-users at lists.osgeo.org
> *Subject:* RE: [mapserver-users] query creation issues
> Hi Steve,
> Thanks for your help. I've managed to get the query outputted. I have a
> couple of additional questions...after creating my query I need the
> footer to show the "name" and the "type" (based on the shapefile
> information), as based on the footer.html below
> <br>
> ALT="Map Image">
> <table border=1>
> <tr> </td>
> <th>Name</th>
> <th>Type</th>
> </tr>
> As when I launch my query it only shows...
> *Name*
> *Type*
> Based on readings from the mapserver website, it looks like I have to
> edit the query.html to make this populated...but not sure where
> (global.map file?) I can get this information that is supposed to go
> between the <td> and </td> tags.
> <!--<IMG
> <tr>
> <td> </td>
> <td></td>
> </tr>
> Thanks,
> Mark
>> From: Steve.Lime at state.mn.us <mailto:Steve.Lime at state.mn.us>
>> To:mmirrlees at hotmail.com <mailto:mmirrlees at hotmail.com>;
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
>> Date: Wed, 20 Mar 2013 17:00:47 +0000
>> Hi Mark: Personally I'd steer you to the simplified query templates as described here:
>>http://mapserver.org/development/rfc/ms-rfc-36.html
>> This allows you to put everything in one place and better separates data from presentation. No more header/footer's. Plus you can have multiple presentations for the same layer.
>> That said, the mapfile below doesn't have any queryable layers. There is no TEMPLATE defined for the one layer that is present.
>> If you want to use the new style templating you'd do something like this:
>> 1- Define an output format:
>> OUTPUTFORMAT
>> NAME 'my-template'
>> DRIVER 'TEMPLATE'
>> MIMETYPE 'text/html; subtype=compass'
>> FORMATOPTION "FILE=templates/my-template.html"
>> END
>> 2- Optionally make it the default query format (otherwise you need to use qformat CGI parameter):
>> WEB
>> QUERYFORMAT 'my-template'
>> END
>> 3- Make layers queryable by adding something like:
>> TEMPLATE 'void'
>> 4- Write your template, for example my-template.html might look like:
>> --- snip ---
>> This is my template:<br/>
>> [resultset layer="mjrroads"]
>> [feature]<b>Type</b>: [TYPE][/feature]
>> [/resultset]
>> Done presenting layers.
>> --- snip ---
>> Steve
>> From:mapserver-users-bounces at lists.osgeo.org
> <mailto:mapserver-users-bounces at lists.osgeo.org>
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mark Mirrlees
>> Sent: Wednesday, March 20, 2013 10:45 AM
>> To:mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
>> Subject: [mapserver-users] query creation issues
>> Hello everyone,
>> I'm trying to create a query so I can query the roads/expressways from the map. I'm pretty sure I have created the headers and footers correctly but not sure...regardless i'm not entirely too sure where to stick the particular code in my .map file (shown below). I have bolded the code that I'm trying to incorporate into the
> .map file but not sure why it's not working. Thanks Mark
>> # Map file created from QGIS project file C:/wwwroot/M_Mirrlees_Assign3/markassign3.qgs
>> # Edit this file to customize for your map interface
>> # (Created with PyQgis MapServer Export plugin)
>> MAP
>> NAME "QGIS-MAP"
>> # Map image size
>> SIZE 500 500
>> UNITS meters
>> EXTENT -2400000 -900000 3100000 4000000
>> FONTSET "/wwwroot/fonts/fontset.txt"
>> SYMBOLSET "/wwwroot/symbols/symbols.sty"
>> PROJECTION
>> "proj=lcc"
>> "ellps=GRS80"
>> "lat_0=49"
>> "lon_0=-95"
>> "lat_1=49"
>> "lat_2=77"
>> "datum=NAD83"
>> "units=m"
>> "no_defs"
>> END
>> # Background color for the map canvas -- change as desired
>> IMAGECOLOR 0 100 250
>> IMAGEQUALITY 95
>> IMAGETYPE agg
>> OUTPUTFORMAT
>> NAME agg
>> DRIVER AGG/PNG
>> IMAGEMODE RGB
>> END
>> # Legend
>> LEGEND
>> IMAGECOLOR 255 255 255
>> STATUS ON
>> KEYSIZE 18 12
>> LABEL
>> TYPE BITMAP
>> SIZE MEDIUM
>> COLOR 0 0 89
>> END
>> END
>> # Web interface definition. Only the template parameter
>> # is required to display a map. See MapServer documentation
>> WEB
>> # Set IMAGEPATH to the path where MapServer should
>> # write its output.
>> IMAGEPATH "/ms4w/tmp/ms_tmp/"
>> # Set IMAGEURL to the url that points to IMAGEPATH
>> # as defined in your web server configuration
>> IMAGEURL "/ms_tmp/"
>> # WMS server settings
>> METADATA
>> 'ows_title' 'QGIS-MAP'
>> 'ows_onlineresource' 'localhost.com/cgi-bin/mapserv.exe?map=C:/wwwroot/M_Mirrlees_Assign3/global.map'
>> 'ows_srs' 'EPSG:4326'
>> END
>> #Scale range at which web interface will operate
>> # Template and header/footer settings
>> # Only the template parameter is required to display a map. See MapServer documentation
>> TEMPLATE 'C:/wwwroot/M_Mirrlees_Assign3/global.html'
>> END
>> SCALEBAR
>> STATUS EMBED
>> UNITS KILOMETERS
>> INTERVALS 3
>> TRANSPARENT TRUE
>> OUTLINECOLOR 0 0 0
>> END # End for scalebar
>> QUERYMAP
>> STATUS ON # sets the map to be queryable
>> STYLE HILITE # the selected object is highligthed
>> END # End for QueryMap
>> WEB
>> TEMPLATE global.html
>> IMAGEURL "/ms_tmp/"
>> HEADER "/maps/M_Mirrlees_assign3/header.html"
>> FOOTER "maps/M_Mirrlees_assign3/footer.html"
>> EMPTY "/maps/M_Mirrlees_Assign3/blank.html"
>> END #End for WEB
>> LAYER
>> NAME 'mjrroads'
>> TYPE LINE
>> DUMP false
>> EXTENT -143.210462 39.001401 -50.461045 85.911094
>> DATA '../data/mjrroads.shp'
>> METADATA
>> 'ows_title' 'mjrroads'
>> END
>> STATUS default
>> TRANSPARENCY 100
>> PROJECTION
>> 'proj=longlat'
>> 'datum=WGS84'
>> 'no_defs'
>> END
>> CLASSITEM 'TYPE'
>> CLASS
>> NAME "default"
>> EXPRESSION ""
>> STYLE
>> WIDTH 0.91
>> COLOR 201 157 32
>> END
>> END
>> CLASS
>> NAME "TYPE = Expressway"
>> EXPRESSION "Expressway"
>> STYLE
>> WIDTH 2.0
>> COLOR 255 0 0
>> END
>> END
>> CLASS
>> NAME "TYPE = Primary Highway"
>> EXPRESSION "Primary Highway"
>> MAXSCALEDENOM 2500000
>> STYLE
>> WIDTH 1.0
>> COLOR 0 0 0
>> END
>> END
>> END
