[mapserver-users] query creation issues
Mark Mirrlees
mmirrlees at hotmail.com
Wed Mar 20 13:39:45 PDT 2013
Hi there
I guess I misread that!
Thanks for everyone's help! As everything is working the way is needed!
Mark
Sent from my BlackBerry® powered by Virgin Mobile.
-----Original Message-----
Date: Wed, 20 Mar 2013 20:13:52
To: <mmirrlees at hotmail.com>; <mapserver-users at lists.osgeo.org>
Subject: RE: [mapserver-users] query creation issues
Did you see this in Steve's email:
> layer=mjrroads&shapeindex=[shpidx]&shpext=[shpext_esc]&mapext=shape&ma
> p=[map]">-->
> <tr>
> <td>[shpidx]</td>
> <tr><td>[name]</td></tr>
> <tr><td>[type]</td></tr>
> </tr>
Attribute binding is case sensitive. For shapefiles it should be UPPERCASE and for postgis it should be lowercase.
Also, you tags are not nested correctly, you have a tr nested inside a tr. :-O
-Steve W
Your data comes from shapefiles. You need to put "name" and "type" in upper case.
[NAME] [TYPE]
Worth
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mark Mirrlees
Sent: Wednesday, March 20, 2013 3:47 PM
To: steve.lime at state.mn.us; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] query creation issues
Does anyone have any updates on how to fix this? As I mentioned before I managed to get the ID field populated whenever I query the map but I need to get the same thing for the name of the road and the type of road...
If there is anything else that you require please let me know as this is causing a great deal of confusion why it won't work!
Thanks,
Mark
Date: Wed, 20 Mar 2013 14:53:57 -0400
Hi there, Ok I managed to get this outputted...but under the [name] and [type] I need to get these fields populated from the query of the mjrroads...
ID
Name
Type
1164
[name]
[type]
Code from mjrroadsquery.html
<!-- MapServer Template -->
<!--<IMG src="http://[host]/cgi-bin/mapserv.exe?mode=INDEXQUERY&qformat=png24&qlayer=mjrroads&shapeindex=[shpidx]&shpext=[shpext_esc]&mapext=shape&map=[map]">-->
<tr>
<td>[shpidx]</td>
<td>[name]</td>
<td>[type]</td>
</tr>
Now if I change the [name] to [map] in the mjrroadsquery.html I get the following...
ID
Name
Type
1164
/wwwroot/M_Mirrlees_Assign3/global.map
[type]
Code from mjrroads.html
<h3><b>Layer: Major Roads</b></h3>
<br>
<INPUT NAME="img" TYPE="image" SRC="[img]" width=500 height=500 border=0 ALT="Map Image">
<table border=1>
<tr> </td>
<th>ID</th>
<th>Name</th>
<th>Type</th>
</tr>
All i'm trying to do is get the Name and Type fields to be showing the name of the road, and the type of the road.
Thanks,
Mark
No virus found in this message.
Checked by AVG - www.avg.com <http://www.avg.com>
Version: 2013.0.2904 / Virus Database: 2641/6189 - Release Date: 03/19/13
