[mapserver-users] Duplicate results with processquerytemplate
Bistrais, Bob
Bob.Bistrais at maine.gov
Fri Mar 29 09:02:53 PDT 2013
I have a strange problem which sometimes occurs when I query multiple layers. I have an application where a user may click checkboxes to select layers to query. I found that if they select all layers, the query results will appear twice for the first layer. I checked several times, and as far as I can see, that first layer is only queried once. It seems that the duplicate processing occurs when $map->processQueryTemplate is called.
Has anyone ever seen a problem like that, and what might anyone suggest as a fix?
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130329/00ab7e04/attachment.html>
