[mapserver-users] Mapserver-- Opracle --SDO_relate function very slow via Mapserver
Simon Mercier
smercier at mapgears.com
Mon May 6 13:16:48 PDT 2013
Hi Rotenhan
You should try to add DEBUG 5 in your layer to log the SQL build by
Mapserver and try to see what going wrong with spatial index (explain
plan in psql).
Simon
Le 13-05-06 11:11 AM, Rotenhan von, Wernher a écrit :
> Hello List
> Im Running Mapsrever 6.0.2 on Oracle 11g Database
> I want to get all geometries that interact with a geometry I clicked
> within
> So I have todo two encapsulated sdo_relate calls :
> --The inner one to get the geometry ic clicked in
> --The outer one to get the geometries which touch the clicked geometries
> This runs very fast within my oracle developer ( 0.09 sec):
> SELECT identnolong,
> gresult.geodata GEODATA
> FROM rms.zrgeo gresult
> WHERE gresult.GEOTYPECODE = '49'
> AND SDO_RELATE ( gresult.geodata ,
> (SELECT gtouching.geodata
> FROM rms.zrgeo gtouching
> WHERE gtouching.geotypecode = '49'
> AND gtouching.IDENTNOLONG =
> (SELECT MAX(gwithin.IDENTNOLONG)
> FROM rms.zrgeo gwithin
> WHERE SDO_RELATE (
> gwithin.geodata ,
> MDSYS.SDO_GEOMETRY(2001,8307,MDSYS.SDO_POINT_TYPE(10.31423,49.692,NULL),NULL,NULL)
> , 'mask=ANYINTERACT') = 'TRUE'
> AND gtouching.geotypecode ='49'
> , 'mask=ANYINTERACT') = 'TRUE';
> But if I include it into my Map file
> the Query becomes very slow 17 sec
> If I force Oracle not to make use of ths spacial index I get nearly
> the same response time
> So is there any possibility to force the use of the spatial indexes ?
> "USING SRID 8307" etc does not Work !!! because the resultset is a
> query and I have to add
> "Using NONE"
> Would be very nice if you could hepl me !
> Regard Wernher
> The information contained in this email is confidential. It is
> intended solely for the addressee. Access to this email by anyone else
> is unauthorized. If you are not the intended recipient, any form of
> disclosure, reproduction, distribution or any action taken or
> refrained from in reliance on it, is prohibited and may be unlawful.
> Please notify the sender immediately.
> mapserver-users at lists.osgeo.org
simon mercier
co-fondateur solutions mapgears
2383 che ste-Foy bur 202 québec, qc
canada G1V1T1
t_418_476_7139#101
m_418_559_7139
simonmercier.net / mapgears.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130506/592bf125/attachment.html>
