[mapserver-users] MAXSIZE on Windows
Luís de Sousa
luis.a.de.sousa at gmail.com
Wed May 8 07:39:52 PDT 2013
Dear all,
I have set up MapServer for the first time on Windows using MS4W, and the
installation itself went well. I then tried to set up a map file and
retrieve the data with QGis. No matter what I always get an error like this:
msWMSLoadGetMapParams(): WMS server error. Image size out of range, WIDTH
and HEIGHT must be between 1 and 32736 pixels.
I'm using map files that I use in Linux without needing to set MAXSIZE. On
Windows not only it seems to be necessary, it seems also to require a large
figure. Anyone knows what size should be set? Or is this error being caused
by something else?
Thank you,
Luis
View this message in context: http://osgeo-org.1560.x6.nabble.com/MAXSIZE-on-Windows-tp5052107.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
