[mapserver-users] MAXSIZE on Windows
Fawcett, David (MNIT)
David.Fawcett at state.mn.us
Wed May 8 07:54:50 PDT 2013
Louis,
I am guessing that QGIS is requesting an image that is too large. You might try enabling debugging to see the WMS request that QGIS is sending. I think that with a high debug level it should log the request.
http://mapserver.org/optimization/debugging.html
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Luís de Sousa
Sent: Wednesday, May 08, 2013 9:40 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] MAXSIZE on Windows
Dear all,
I have set up MapServer for the first time on Windows using MS4W, and the installation itself went well. I then tried to set up a map file and retrieve the data with QGis. No matter what I always get an error like this:
msWMSLoadGetMapParams(): WMS server error. Image size out of range, WIDTH and HEIGHT must be between 1 and 32736 pixels.
I'm using map files that I use in Linux without needing to set MAXSIZE. On Windows not only it seems to be necessary, it seems also to require a large figure. Anyone knows what size should be set? Or is this error being caused by something else?
Thank you,
Luis
View this message in context: http://osgeo-org.1560.x6.nabble.com/MAXSIZE-on-Windows-tp5052107.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
