[mapserver-users] [TinyOWS] Unable to open config file
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Mon May 13 01:01:09 PDT 2013
I have always used tinyows.xml configuration file, but in
http://mapserver.org/trunk/tinyows/mapfileconfig.html
there reads
"To indicate where your Mapfile is located, to TinyOWS binary, use the ''TINYOWS_MAPFILE'' environment variable."
Perhaps the environment is set for you when you run tinyows --check but not for the web user?
-Jukka Rahkonen-
Luca Delucchi wrote:
> On 9 May 2013 17:19, Worth Lutz <wal3 at mindspring.com> wrote:
> > I have not used TinyOWS but it sounds like a permission problem on the
> > config file.
> > Is it readable by the web user (www-data in ubuntu)
> Yes it is readable...
> > Worth
> thanks
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> mapserver-users at lists.osgeo.org
