[mapserver-users] How to configure mapserver as a tile server?
Hishan Melanga
hishanm at gmail.com
Sat May 25 06:47:32 PDT 2013
ok. Now I have http://example.com/mapcache/demo working. But how can I get
my mapserver's wms connect to it.
On Sat, May 25, 2013 at 10:42 AM, Hishan Melanga <hishanm at gmail.com> wrote:
> Thanks. I installed mapcahe and started to learn about the xml
> configuration file. Reading http://mapserver.org/mapcache/config.html as
> a start. Hope it is the first thing that I should do.
> On Sat, May 25, 2013 at 8:07 AM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> On 5/24/2013 10:06 PM, Hishan Melanga wrote:
>>> I have a working mapserver and I can view my map using
>>> http://localhost/cgi-bin/**mapserv?map=/path/to/map&mode=**
>>> browse&template=openlayers&**layers=all<http://localhost/cgi-bin/mapserv?map=/path/to/map&mode=browse&template=openlayers&layers=all>
>>> Now I want to give out those data to public as tiles giving a single URL
>>> such as tile.myserver.org <http://tile.myproxy.org/>. How can I achieve
>>> this using Mapserver? What is the place to start? What tutorials I have
>>> to read? I've read that Mapserver has a tile mode
>>> <http://mapserver.org/output/**tile_mode.html<http://mapserver.org/output/tile_mode.html>
>>> Thanks in advance.
>> mapcache it the tile server for mapserver. So you will want to look at
>> that. The basic scenario is this:
>> 1. setup mapserver as a WMS server
>> 2. build and install mapcache as an apache module
>> 3. setup a mapcache.xml to describe you WMS server, and your cache.
>> make sure you configure the demo service initially for testing
>> you can disable it later if you want
>> 4. restart apache
>> 5. http://example.com/mapcache/**demo <http://example.com/mapcache/demo>
>> whenever you change your mapcache.xml you need to start apache so it
>> reads your changes.
>> -Steve W
>> ______________________________**_________________
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.**org <mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/**mailman/listinfo/mapserver-**users<http://lists.osgeo.org/mailman/listinfo/mapserver-users>
> හිෂාන් මෙලංග | Hishan Melanga <http://hishanmelanga.blogspot.com/>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130525/9ee64306/attachment-0001.html>
