[mapserver-users] Mapcache tileset only shows top level in KML / Google Earth
John D. Evans
john.evans at gst.com
Mon May 27 21:30:29 PDT 2013
Hello,
I'm making my first mapcache tileset for some satellite image products.
It sort of works ... but the KML super-overlay doesn't work as expected
in Google Earth. When I load it, it only displays if I'm zoomed very far
out (so that the entire globe is the size of a golf ball on my screen):
if I zoom in, the image disappears.
The KML file is at
http://lab.gst.com/mapcache/kml/CSPP_Cloud_Phase_EDR@WGS84.kml
and my mapcache.xml is below. Do you see anything obviously misconfigured?
(I'm using mod_mapcache from the Ubuntu libmapcache 1.0.0-3 package;
with Apache 2.2 and Mapserver 6.2.1; on 64-bit Ubuntu 12.04. Mapserver
works fine, and reports no errors that I can see. My client is Google
Earth 7.0.3. Unfortunately, I don't know where to look for mapcache
error messages.)
Thanks for taking a look,
- John D. Evans
GST, Inc / Greenbelt, MD
Below is my mapcache.xml file (actually an excerpt of it:
the real one has more tilesets and sources).
<mapcache>
<metadata>
<title>my mapcache service</title>
<abstract>woot! this is a service abstract!</abstract>
</metadata>
<cache name="disk" type="disk">
<base>/tmp</base>
<symlink_blank/>
</cache>
<format name="PNG_BEST" type ="PNG">
<compression>best</compression>
</format>
<format name="PNG_FAST" type ="PNG">
<compression>fast</compression>
</format>
<source name="CSPP_CloudPhase" type="wms">
<http>
<url>http://localhost/cgi-bin/mapserv?</url>
</http>
<getmap>
<params>
<FORMAT>image/png</FORMAT>
<LAYERS>iicmocp_daily</LAYERS>
<MAP>/path/to/mapfile.map</MAP>
</params>
</getmap>
</source>
<tileset name="CSPP_Cloud_Phase_EDR">
<metadata>
<title>VIIRS Cloud Phase from NASA GSFC DRL</title>
<abstract>Detailed description goes here</abstract>
</metadata>
<source>CSPP_CloudPhase</source>
<cache>disk</cache>
<format>PNG</format>
<grid>WGS84</grid>
<metatile>2 2</metatile>
<expires>3600</expires>
<auto_expire>3600</auto_expire>
<!-- <metabuffer>10</metabuffer> -->
</tileset>
<default_format>PNG_FAST</default_format>
<service type="wms" enabled="true">
<full_wms>assemble</full_wms>
<resample_mode>bilinear</resample_mode>
<format>PNG_FAST</format>
<!-- <maxsize>4096</maxsize> -->
</service>
<service type="wmts" enabled="true"/>
<service type="tms" enabled="true"/>
<service type="kml" enabled="true"/>
<service type="gmaps" enabled="true"/>
<service type="ve" enabled="true"/>
<service type="demo" enabled="true"/>
<lock_dir>/tmp</lock_dir>
<errors>report</errors>
<threaded_fetching>true</threaded_fetching>
</mapcache>
