[mapserver-users] Mapserver PostGIS Points Layer coming up blank
Stephen Woodbridge
woodbri at swoodbridge.com
Fri May 31 14:10:25 PDT 2013
Try adding the following to your mapfile.
-Steve W
On 5/31/2013 3:52 PM, Michael McInnis wrote:
> Dear Mapserver List,
> I've progressed to the point where the following does not show any
> errors but the subsequent map image is blank/white.
> I confirmed INPUT=POSTGIS shows up with mapserv -v and I know the table
> is constructed properly because I can display it easily in QGIS.
> Any help debugging this would be greatly appreciated.
> I was successful rendering shapefiles with my mapserver installation.
> Another possible clue is that if I uncomment the STYLE/SYMBOL line I get
> an error it can't find the following:
> unable to open file /ms4w/apps/gmap/htdocs/circle for reading
> Install :
> MapServer version 6.0.3 from MS4W
> PostGreSQL 9.0.13
> PostGIS 2.0
> Map File :
> MAP
> NAME airports
> EXTENT -180 -90 180 90
> SIZE 1000 500
SYMBOL
NAME "circle-filled"
TYPE ELLIPSE
FILLED TRUE
POINTS 1 1 END
END
> LAYER
> CONNECTIONTYPE POSTGIS
> NAME "airports"
> CONNECTION "host=localhost dbname=Business user=####
> password=#### port=5432"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> DATA "geomll From airports"
> STATUS ON
> TYPE POINT
> CLASS
> NAME "airportsClass"
> STYLE
> #SYMBOL 'circle'
SYMBOL 'circle-filled'
SIZE 4
> COLOR 255 22 22
> END
> END # Class
> END # Layer
> END # Map File
> http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/gmap/htdocs/airports.map&layer=airports&mode=map
> This produces a black background with a 1000 pixel by 500 pixel white
> space in Firefox.
> mapserver-users at lists.osgeo.org
